ADC sensing code needed using pic16f676\16f72
sahu
dear friend
i am new in pic project.
pls help me .
pl help
ADC sensing code needed using pic16f676\16f72 in asm formet.
Have a look at this code and convert it to suit your needs...
; Author  : Mike Baird
; Program : ADC Example, Takes ADC result from AN0 and display LSB on PORTB
; Date    : September 7th, 2009
	List	P=16F88
	#include	"P16F88.INC"
	__CONFIG	_CONFIG1,   _PWRTE_ON  & _WDT_OFF & _INTRC_IO & _BODEN_OFF & _LVP_OFF & _CP_OFF & _MCLR_OFF
	__CONFIG    _CONFIG2,	_IESO_OFF & _FCMEN_OFF
;*** Cblock ***
	CBLOCK	0x20
	d1
	d2
	ADCLOW
	ADCHIGH
	ENDC
;*** START OF RAM ***
	ORG	0x000							; Start of program vector
	GOTO	Start						;
	ORG	0x004							; Interrupt vector
;*** ISR ***
	RETFIE
;*** Configuration ***
Start
	CLRF	PORTA						; PortA all low
	CLRF	PORTB						; PortB all low
	BSF		STATUS,RP0					; Bank 1
	MOVLW	b'01100000'					; Make clock 4Mhz
	IORWF	OSCCON
	MOVLW	b'00100001'					; Bit 5 input, Bit 0 for ADC
	MOVWF	TRISA						; PortA all output except MCLR
	CLRF	TRISB						; PortB all output
	MOVLW	b'00000001'					; Set RA0 as analog input
	MOVWF	ANSEL						;
	MOVLW	b'10000000'					; MSB on the left (Top 6 bits of ADRESH = 0 )
	MOVWF	ADCON1						;
	BCF		STATUS,RP0					; Bank 0
	MOVLW	b'11000001'					; Set ADC input to AN0, clock FAD, turn on ADC
	MOVWF	ADCON0						;
Main:
	CALL 	Delay1ms					; Wait MUCH longer then required aquasition time, see below for time
	BSF		ADCON0,GO
	BTFSC	ADCON0,GO					; Wait for conversion to be complete
	GOTO	$-1							;
	BCF		PIR1,ADIF
	CALL	ADCMOVE
	MOVF 	ADCLOW,W					;
	MOVWF	PORTB						;
	CALL 	Delay
	GOTO 	Main						;
ADCMOVE:
	MOVF	ADRESH,W					;
	MOVWF	ADCHIGH						;
	MOVF	ADRESL,W					;
	MOVWF	ADCLOW						;
	RETURN
;*** Delay ***
Delay1ms
	MOVLW	d'6'    ; 1 Ms Delay  (924 uS)
	MOVWF d2
Delay
	DECFSZ	d1,F
	GOTO	Delay
	DECFSZ	d2,F
	GOTO	Delay
	RETURN
	END
; That's all folks!
; Note: On a Power-on Reset, the pins PORTA<4:0> are configured as analog
; inputs and read as ‘0’.
;	ANSEL: ANALOG SELECT REGISTER(ADDRESS 9Bh) PIC16F88 DEVICES ONLY
;	Bit7 =  Unimplemented: Read as ‘0’
;	Bit 6:0 = ANS<6:0> Analog Input Select bits
;		Bits select input function on corresponding AN<6:0> pins.
;		1 = Analog I/O(1,2)
;		0 = Digital I/O
;	Note 1: Setting a pin to an analog input disables the digital input buffer. The corresponding
;	TRIS bit should be set to input mode when using pins as analog inputs. Only AN2 is
;	an analog I/O, all other ANx pins are analog inputs.
;	2: See the block diagrams for the analog I/O pins to see how ANSEL interacts with the
;	CHS bits of the ADCON0 register.
;	ADCON0: A/D CONTROL REGISTER (ADDRESS 1Fh)   b'00000001'
;	bit 7-6 ADCS<1:0>: A/D Conversion Clock Select bits
;		If ADCS2 = 0:
;		00 = FOSC/2
;		01 = FOSC/8
;		10 = FOSC/32
;		11 = FRC (clock derived from the internal A/D module RC oscillator)
;		If ADCS2 = 1:
;		00 = FOSC/4
;		01 = FOSC/16
;		10 = FOSC/64
;	bit 5-3 CHS<2:0>: Analog Channel Select bits
;		000 = Channel 0 (RA0/AN0)
;		001 = Channel 1 (RA1/AN1)
;		010 = Channel 2 (RA2/AN2)
;		011 = Channel 3 (RA3/AN3)
;		100 = Channel 4 (RA4/AN4)
;		101 = Channel 5 (RB6/AN5)
;		110 = Channel 6 (RB7/AN6)
;	bit 2 GO/DONE: A/D Conversion Status bit
;		If ADON = 1:
;		1 = A/D conversion in progress (setting this bit starts the A/D conversion)
;		0 = A/D conversion not in progress (this bit is automatically cleared by hardware when the A/D
;		conversion is complete)
;	bit 1 Unimplemented: Read as ‘0’
;	bit 0 ADON: A/D On bit
;		1 = A/D converter module is operating
;		0 = A/D converter module is shut off and consumes no operating current
;	ADCON1: A/D CONTROL REGISTER 1 (ADDRESS 9Fh)PIC16F88 DEVICES ONLY
;	bit 7 ADFM: A/D Result Format Select bit
;		1 = Right justified. Six Most Significant bits of ADRESH are read as ‘0’.
;		0 = Left justified. Six Least Significant bits of ADRESL are read as ‘0’.
;	bit 6 ADCS2: A/D Clock Divide by 2 Select bit
;		1 = A/D clock source is divided by 2 when system clock is used
;		0 = Disabled
;	bit 5-4 VCFG<1:0>: A/D Voltage Reference Configuration bits
;		Logic State VREF+ VREF-
;		00 AVDD AVSS
;		01 AVDD VREF-
;		10 VREF+ AVSS
;		11 VREF+ VREF
;		Note: The ANSEL bits for AN3 and AN2 inputs must be configured as analog inputs for the
;		VREF+ and VREF- external pins to be used.
;	bit 3-0 Unimplemented: Read as ‘0’
;	These steps should be followed for doing an A/D conversion:
;	1. Configure the A/D module:
;		• Configure analog/digital I/O (ANSEL)
;		• Configure voltage reference (ADCON1)
;		• Select A/D input channel (ADCON0)
;		• Select A/D conversion clock (ADCON0)
;		• Turn on A/D module (ADCON0)
;	2. Configure A/D interrupt (if desired):
;		• Clear ADIF bit
;		• Set ADIE bit
;		• SET PEIE bit
;		• Set GIE bit
;	3. Wait the required acquisition time.
;	4. Start conversion:
;		• Set GO/DONE bit (ADCON0)
;	5. Wait for A/D conversion to complete, by either:
;		• Polling for the GO/DONE bit to be cleared
;		(with interrupts disabled); OR
;		• Waiting for the A/D interrupt
;	6. Read A/D Result register pair (ADRESH:ADRESL), clear bit ADIF if required.
;	7. For next conversion, go to step 1 or step 2 as required. The A/D conversion time per bit is
;	defined as TAD. A minimum wait of 2 TAD is required before the next acquisition starts.
;	EQUATION 12-1: ACQUISITION TIME
;	TACQ = Amplifier Settling Time + Hold Capacitor Charging Time + Temperature Coefficient
;        = TAMP + TC + TCOFF
;	     = 2 µs + TC + [(Temperature -25°C)(0.05 µs/°C)]
;	TC   = CHOLD (RIC + RSS + RS) ln(1/2047)
;	     = -120 pF (1 kO + 7 kO + 10 kO) In(0.0004885)
;	     = 16.47 µs
;   	 = 2 µs + 16.47 µs + [(50°C – 25°C)(0.05 µs/°C)
;	TACQ = 19.72 µs
	List	P=16F88
;*** Cblock ***
	CBLOCK	0x20
	d1
	d2
	ADCLOW
	ADCHIGH
	ENDC
	GOTO	Start						;
;*** ISR ***
	RETFIE
Start
	IORWF	OSCCON
	MOVWF	ANSEL						;
	MOVWF	ADCON1						;
	MOVWF	ADCON0						;
Main:
	BSF		ADCON0,GO
	GOTO	$-1							;
	BCF		PIR1,ADIF
	CALL	ADCMOVE
	MOVF 	ADCLOW,W					;
	MOVWF	PORTB						;
	CALL 	Delay
	GOTO 	Main						;
ADCMOVE:
	MOVF	ADRESH,W					;
	MOVWF	ADCHIGH						;
	MOVF	ADRESL,W					;
	MOVWF	ADCLOW						;
	RETURN
;*** Delay ***
Delay1ms
	MOVWF d2
Delay
	DECFSZ	d1,F
	GOTO	Delay
	DECFSZ	d2,F
	GOTO	Delay
	RETURN
	END
; That's all folks!
;		0 = Digital I/O
;		If ADCS2 = 0:
;		00 = FOSC/2
;		01 = FOSC/8
;		10 = FOSC/32
;		If ADCS2 = 1:
;		00 = FOSC/4
;		01 = FOSC/16
;		10 = FOSC/64
;		If ADON = 1:
;		0 = Disabled
;		00 AVDD AVSS
;		01 AVDD VREF-
;		10 VREF+ AVSS
;		11 VREF+ VREF
;		• Clear ADIF bit
;		• Set ADIE bit
;		• SET PEIE bit
;		• Set GIE bit
;	     = 16.47 µs
;	TACQ = 19.72 µs
thanks giving for exp. for adc. i am new in microontrller .so pl ........ convert it 16f676\16f72.
Since it appears to be a school project this might be a good time to learn to work with assembly code. What would you learn if someone did all your assignments for you.
The only way I could see this being a reasonable demand, is that the datasheet is in english and thats not your first language...
dear sir
my first language is HINDI & my english is very poor.....so can u help me ?
