Accessing array of variables
Hello I am working on a project. I am using MicroC pro for PIC microcontroller. I have created, say, 10 arrays-
const char V01 [15]= { some 15 values }
const char V02 [15]= { some 15 values }
const char V10[15]= { some 15 values }
Now I want to access values from V01 to V10. I tried to make another array "VX" of variables V01 to V10. But could not succeed. I am also confused between pointers, array of pointers, addresses, datatype of variable VX etc and how to put in the code.
I also tried-
value = VX [n];
if (some logic) VX = V01;
else if (some logic) VX = V02;
else VX = V10;
Note- 2-D array is not a solution for me.
You are very nearly there.. Create one pointer
const char* VX;
Then point it to the start of each array..
if (some logic) VX = &V01[0];
else if (some logic) VX = &V02[0];
else VX = &V10[0];
Then access like this..
VX[10] = xxx;
Okay!! In C, an array name is essentially a pointer.. So!!
char array[10]; //Set up a variable array..
char * arrayptr = &array[0]; //Point to first location..
Now this statement..
x = array[3];
is exactly the same as
x = arrayptr[3];
if you had another character array..
char array2[10];
you can point to it with the same pointer..
arrayptr = &array2[0];
But the pointer can be moved whereas the array name cannot!
