Quotes from Ratchit
MrAl,
By "not as good", I hope you mean that "charge" is not as descriptive as "energize" when referring to a voltage across a capacitor. I don't see how energize is ambigous.
>I thought i made that clear with the light bulb. The light bulb being energized does not charge up, while the capacitor does. Thus, if we say energized it doesnt seem as clear.
The ability to store or dissipate energy is irrelevant to the word energize.
>Yes, that's what i am saying. That's why it is ambiguous. With 'charge' we know right away.
Certainly not. Turning on a light bulb is certainly energizing it.
>But it's not charging so i couldnt say charge. It's not going to be holding anything, while the cap does hold something.
Clear because it has become an accepted description that you mean you are going to electrically energize it. Not really true, however, because it does not contain any more charge after energizing it that it did before. But, it does contain more energy.
>So you dont accept the term 'charge' that is known by the world over. Remember this for later.
From knowing what it is and the context, most folks would assume you mean electrically energize.
>Most folks? So now we can go with the normal human assumptions but for the word 'charge' we can not? What if i pour acid into the battery?
Could be either one or both. If you said "charge", what would that tell anyone?
>Charge implies that something is being stored. Energize does not make that distinction. If i say that i energized a circuit you wont know if it is storing any energy. If i say i charged a certain circuit you know something is being stored.
It depends on the component, the state of the component, and the circuit.
>For 'energize' yes, we dont know.
>For 'charge' however we know right away.
I think both words are precise when used in the proper context. I aver that "charge" is often not used correctly. Often "energize" is the better word to use.
>Ok if you want to say that that's up to you. Im not saying that it is totally wrong either, just that 'charge' is not only accepted, it is descriptive if you look at it as charge being stored and then dumped later. It acts like it stores charge so we say 'charge'. There are a few different views on what really happens too including virtual particles. Im not sure i want to get into that one though
Negative. Current does not exist through a capacitor, and charge does not flow through a capacitor, unless there is leakage. Your next statement says as much.
>Well, depending on the view i guess. External measurements would say otherwise too and the external measurements are important in analyzing circuits. If we connect a constant current generator up to a capacitor we couldnt have a complete circuit unless there was the closure of the path so it would not start to store energy if there was not a complete circuit there. It's hard to say that no current flows 'through' the capacitor. Who cares really? If it goes in one side and appears to come out the other side and always works that way we're all set.
That is correct. Charge accumulates on one plate and depletes equally on the other plate. If the charge passed through the capacitor, then it would not accumulate or deplete. So no charge would separate, no electric field would form, and no energy would be stored. That proves that charge does not go through a capacitor.
>That view seems fine. But it's just that view.
You asked what is flowing. Charge would be correct, and flowing means moving charge. Current is also correct, because moving charge defines current. Energy is also correct because energy changes when charge moves through a resistance.
>Yeah but when we think of energy we think of E=1/2 C*V^2, and although that is very descriptive of the energy it doesnt tell us what is happening an infinitesimal distance from one of the plates.
Yes, the electric field does store energy, but the descriptive term is false for this phenomena. The net charge does not change, but the energy certainly does.
>Ok.
I have never heard of a coil being called charged, but if so, that would not be true either. Coils can store energy.
>Yes inductors are also said to be 'charged' quite commonly. We dont have to talk about the field though when we talk about inductors until we get to the finer points of the inductor.
Some of the above I do agree with and some I don't
>Ok that's cool. I think i may have deviated a little from the main point of the thread anyway
