Dear Engineers,
The Flame 180A is a 3-phase inverter and inverter controller for a BLDC. It runs off a 6S or 14S lithium battery. (22-52v)
https://store-en.tmotor.com/goods.php?id=733
This video shows it..
There is no documentation with it. (as the video says)
Does the “180A” refer to the average supply current to the inverter from the battery…or does it refer to the peak phase current?
Also, with a 14S, that’s 52Vin, which means at 180A, that’s 9.3kW……just looking at the Flame 180A, it just doesn’t look like a 9.3kW inverter. It looks way too small. Would you agree? (Even with high speed blown air going over it)...see it at1:32 in the video if you wish
In the video at 1:32 you can see the tiny input capacitor bank…that’s all it is…7 capacitors of the size you see there…they are each 330uF,63V, 105degc....this surely is nowhere near enough for a 9.3kW 3-phase inverter to a BLDC. (I will try and find out the part numbers and do the calcs.)
Current measurement:
We’d like to use a 250A unidirectional Allegro-Micro Hall sensor to sense the current from the battery when the Flame 180A is operating.…..
ACS772 Hall current sensor
ACS772ECB-250U-PFF-T
https://www.allegromicro.com/en/Pro...ed-Amp-Integrated-Conductor-Sensor-ICs/ACS772
Do you believe 250A will be big enough to catch the peak of the battery supply current?
