desperadogear
help needed urgently. im looking for a programmer that would program any of 89c51,89c52,89c205 using parallel port.. any help would be appreciated
This helps?desperadogear said:help needed urgently. im looking for a programmer that would program any of 89c51,89c52,89c205 using parallel port.. any help would be appreciated
I can't wait to see an ISR that fits into 8 bytes!!http://freewebs.com/80x51 said:One strong point of the 8051 is the way it handles interrupts. Vectoring to fixed 8-byte areas is convenient and efficient. Most interrupt routines are very short (or at least they should be), and generally can fit into the 8-byte area. Of course if your interrupt routine is longer, you can still jump to the appropriate routine from within the 8 byte interrupt region.
