8051 assembly code for counter
Parth86
I want make counter program for 8051 controller in assembly that count 0 to 9 I know I have to use counter, timer, interrupt routine , instruction set ( mov, add INC DEC....) now problem is that I have no idea how to start please anyone will help me to write code
Right O... I'll be at home in about an hour...
I'll put a skeletal ASM program together ( actually I already have one ) and post it soon..
ok can you tell me what is the use of register bank and SFR in ram i think register bank is used to store location of data
and don't know about SFR
I just put this together
Its a start at least..
RS     BIT P3.1        ; LCD
RW     BIT P3.2        ; Constants
E     BIT P3.0        ;
BZ    BIT P1.7        ; busy flag
    org     0h        ; reset vector
    sjmp    Start
    org    20h        ; jump over vectors
; Start of code
Start:
    acall    LcdInit        ; called once only
While:
    acall    LcdLine1    ; Goto Line1
    mov     DPTR,#MSG1
    acall    LcdPrint    ; Display message
    acall    LcdLine2    ; goto Line2
    mov     DPTR,#MSG2    ;
    sjmp    While        ; forever loop
MSG1:
    db    "First Line ",0
MSG2:
    db    "Second Line ",0
; Initialize LCD
LcdInit:
    clr    RW
    acall    delay40Ms
    mov    P1,#33h        ; Init once
    setb    E
    clr    E
    acall    delayMs        ; Init twice
    setb    E
    clr    E
    acall    delayMs        ; Now busy can be read.
    mov    a,#38h        ; Function set: 8 bits: 2 Line : font 5x7.
    acall    LcdCom
    mov    a,#0Ch        ; Display On: Cursor Off : Blink Off.
    acall    LcdCom
    mov    a,#06h        ; Shift forward.
    acall    LcdCom
    mov    a,#01h        ; Clear Goto position 1.
    acall    LcdCom
    ret
; Goto first line
LcdLine1:
    mov    A,#80h        ; position 1 on line 1
    acall    LcdCom
    ret
; Goto second line
LcdLine2:
    mov    A,#0C0h        ; position 1 on line 2
    acall    LcdCom
    ret
; Print a null terminated string
LcdPrint:
    mov    A,#0h
    movc    A,@A+DPTR    ; Through string until 0
    cjne    A,#0,Char    ;
    ret
Char:
    acall    LcdData        ; Print data character
    inc    dptr
    sjmp    LcdPrint
; Waiting for LCD module
LcdBusy:
    mov    P1,#0FFh    ; tristate the port
    clr    RS        ; command mode
    setb    RW        ; Read flags
busy:    clr    E
    setb    E
    nop
    jb    BZ, busy    ; wait until ready
    clr    E
    clr    RW        ; Back to write mode
    ret
; Send command to LCD module
LcdCom:                ; sends a command
    acall    LcdBusy
    clr    RW
    clr    RS
    mov    P1,A        ; Acc has command
    setb    E
    clr    E
    ret
; Send data to LCD module
LcdData:            ; Sends data
    acall    LcdBusy
    clr    RW
    setb    RS
    mov    P1,A        ; Acc has data
    setb    E
    clr    E
    ret
; Delays
delay40Ms:
    mov    R1,#25h        ; Simple delay @ 40 milli seconds
dlyM:    acall    delayMs
    djnz    R1,dlyM
    ret
delayMs:
    mov    R0,#0h        ; Simple delay @ 1.1 milli second
dlyU:    nop
    nop
    djnz    R0,dlyU
    ret
    end
[code]
We'll do some interrupts later..
RS     BIT P3.1        ; LCD
E     BIT P3.0        ;
    sjmp    Start
; Start of code
Start:
While:
    mov     DPTR,#MSG1
    mov     DPTR,#MSG2    ;
MSG1:
    db    "First Line ",0
MSG2:
    db    "Second Line ",0
; Initialize LCD
LcdInit:
    clr    RW
    acall    delay40Ms
    setb    E
    clr    E
    setb    E
    clr    E
    acall    LcdCom
    acall    LcdCom
    acall    LcdCom
    acall    LcdCom
    ret
; Goto first line
LcdLine1:
    acall    LcdCom
    ret
; Goto second line
LcdLine2:
    acall    LcdCom
    ret
LcdPrint:
    mov    A,#0h
    cjne    A,#0,Char    ;
    ret
Char:
    inc    dptr
    sjmp    LcdPrint
LcdBusy:
busy:    clr    E
    setb    E
    nop
    clr    E
    ret
    acall    LcdBusy
    clr    RW
    clr    RS
    setb    E
    clr    E
    ret
    acall    LcdBusy
    clr    RW
    setb    RS
    setb    E
    clr    E
    ret
; Delays
delay40Ms:
dlyM:    acall    delayMs
    djnz    R1,dlyM
    ret
delayMs:
dlyU:    nop
    nop
    djnz    R0,dlyU
    ret
    end
[code]
hello ion, this code is very difficult to understand me where you used interrupt subroutine where is timer mode i have read to write counter program we need interrupt timer mode
I said we'll do that later... I need you to understand the code for the LCD first..
As we introduce interrupts I can explain the timer and the external count!
Which assembler do you want to use... I would recommend ASEM51...
I have purposely used the INT pins so you can see what happens when you design systems... You can have a PCB made, then find out you need to use alternate pins for something else...
I will show you an interrupt routine first.... Then I will see if you can integrate the two
countl    equ    20h
counth    equ    21h
    sjmp    Start
    org    03h        ; Ex0 interrupt
    sjmp    ISR
; Start of code
Start:
    setb    P3.2        ; INT0 as input
    setb    IT0        ; Set level of interrupt
    mov    IE,#081h    ; Global On : INT0 On..
While:
ISR:
    mov    A,countl    ; get counter low byte
    mov    B,counth    ; get counter high byte
    add    A,#1        ; increase counter low
    jnc    non        ; are we at 255
    inc    b        ; yes! increase Counter high
non:    mov    countl,A    ; store Low
    mov    counth,B    ; store High
    clr    IE0        ; ensure flag off.
    reti            ; return from interrupt..
    end
Tell me if you understand this.... If not I'll go through it with you..
first thanks for help' can you explain with theory I want to understand some basic things that is used in every counter program I want to understand what basic instruction I need to use to create every counter program in theory I have read loading data transfer arithmetic logic instruction I know how to make loop, labels directives I want to create some basic algorithm for counter program for begainer
Well just look at the code I posted..
The counter is incremented on the high to low transition on P3.2 (INT0) pin.
If the countl variable overflows, the counth variable is incremented, thus giving a 16 bit counter.
Next we need a BCD routine to be able to print the count to a screen..
You can also use a built in timer as a counter... If you just want to count with a register then the simplest command is inc A This just increases Acc by one...
As Far as I know,
.MODEL SMALL
.STACK 100H
.DATA
PROMPT DB 'The counting from 0 to 9 is : $'
.CODE
MAIN PROC
MOV AX, @DATA
MOV DS, AX
LEA DX, PROMPT
MOV AH, 9
INT 21H
MOV CX, 10
MOV AH, 2
MOV DL, 48
loop:
INT 21H
INC DL
DEC CX
JNZ loop
MOV AH, 4CH
INT 21H
MAIN ENDP
END MAI
