What is the correct way to hook up a 7812 voltage regulator.
First 2 drawing are online instructions. 1 drawing shows .33 uf cap another shows .47 uf cap. Tried them both 50 vdc rating.
Third drawing is how I have it connected.
I wired it as shown, turn on the DC power supply and the meter says I have 12 VDC on pin 3. It works.
With NO load, after 45 to 60 seconds they over heat and explode.
First 7812 blew the new 50 volt electrolitic capacitor and killed the 7812.
Second 7812 was testing good 12 VDC when it over heated and exploded into brown smoke.
Third 7812, too hot to tough after 30 seconds. I turned it off before it blew.
Caps all test good. I changed the caps the 7812 show 12 vdc each time but the darn thing over heats with NO LOAD.
Meter reads 12 volts from ground to pin 3 and 3 volts from pin 3 to +15. It seems to work, I dont know why they over heat with no load?
