741 op Amp data sheet request + 10 applications..
sonaiko
hey guys..
I need the data sheet for the 741 opAmp and i need u to tell me 10 of its applications plz...
thanx..
samcheetah said:
go to **broken link removed** for the datasheet
and for applications just search 741 on google and you will be astonished to see the numerous applications of 741 you will find
man i found the data sheet but i couldnt find the 10 applications..
plz help me more..
is this some kind of homework??
anyway, search for the following documents
Opamps for everyone (https://www.ti.com)
A Current Feedback Op-Amp Circuit Collection (https://www.ti.com)
A Differential Op-Amp Circuit Collection (https://www.ti.com)
Op Amp and Comparators – Don’t Confuse Them! (https://www.ti.com)
Understanding Basic Analog – Ideal Op Amps (https://www.ti.com)
A Single-Supply Op-Amp Circuit Collection (https://www.ti.com)
Application of Rail-to-Rail Operational Amplifiers (https://www.ti.com)
An Applications Guide for Op Amps (National Semiconductor)
Monolithic Op Amp The Universal Linear Component (National Semiconductor)
AN165 - Integrated operational amplifier theory (Philips)
tell me if you arent able to find these documents.
in addition to these documents i would recommend the following webpage
mostly some parameters of op-amp are not given in datasheets
that parameters are given below
voltage range=+-3v to +-18v ( it wont work if gnd applied on VEE)
frequency of operation=1MHz theoritcally 20KHz(practically)
(note this parameter for designing of filters)
for more abt stability of opamp, OTA and other parameters mail me
at [email protected]
application:
sine wave to square/pulse converter
suntracker( the project i am doing now)
see some books like Gaykward(5th sem electronics)
