3x3x3 LED Cube - can i use16f628 instead 16f690
If you use the code posted on post 294
IT hooks up on PORTA.2 turns on layer1
PORTA.6 turns on layer2
PORTA.7 turns on layer3
PORTB 0 to 7 are led's 1 to 8 and PORTA.3 is led 9
MCLR is input only and portA4 can only sink power and all the posted stuff would of been better if some dummy being me would of used better names for my sch and looked to see if the right one got posted.
When I did the change from the 16f690 I did this for a bunch of chips and some of them could RA5 I had a bunch of kids making these. Ran out of 16f628a fast and 16f690
Need Help
I made the LED cube given in this site and with 16f84a it worked fine. Then I tried to modify the assembly code to use 16f628a. With the new code cube works for nearly one minute and then it stops at one random LED pattern. Can anybody guess what would be the problem? I used RB0-RB7 & RA0 for LEDs and RA1-RA3 for layers.
The problem here is I posted like four sch four this each with the same name and some how people get the wrong one and end up putting a roll on the wrong pin.
be80be That's what I'm using:
