3x3x3 LED Cube - can i use16f628 instead 16f690
Hello be80be,
I just finished reading the whole post and I think I'm ready to modify the .asm file to work for my 16f872.
I was wondering what program you use to make your schematics ?
Thank you for your help !
be80be,
I saw in your code for the PIC16f628 the line
movwf CMCON ;turn comparators off (make it like a 16F84)
Should I let it there for a PIC16F872 and why ?
Thanks, I read the awesome Gooligum tutorials (https://www.electro-tech-online.com/custompdfs/2011/04/PIC_Base_A_1.pdf)
and I think I'll be okay to change the other lines for a 16F872
EDIT : I did the first line changes and I'm not sure of these lines
movwf CMCON ;turn comparators off (make it like a 16F84) ?
org 0x0000 ;org sets the origin, 0x0000 for the 16F628 and for the 16F872 ?
movlw d'50' ;delay 250 ms (4 MHz clock) ( with a 16F872, there is no internal oscillator so I'll need to make an external one. With a RC osc (easier) I can reach 3.5MHZ, would it be engouh ? no ? What would be the code to fit with a 3.5 MHz clock
Again, thanks for your useful comments !
Weepet
Finished
Hey guys :D
It's working !
Thanks for the help !
I'll try to post a video of my 3x3x3 LEB Cube with a PIC16F872 soon.
I am also interested in this led cube project but I have a 16F88 Pic. Has anyone written an asm or hex file for this chip?
It's not that hard to do just set the chips configure and pints up that your going to use and it should work fine with that chip.
Hey folks, I am also trying to create this cube with the PIC 16F628 and i have went through all the pages of this thread and downloaded all the files.
It seems that every asm/hex file and every schematic has slight variations with respect to the LED lines.
Can someone point me to the correct combination that will work :)
I appreciate it !!
Pete
It's not that hard there one pin on the 16F628 that's can't output 5 volts and thats what made this thread so long lol.
I no longer have code for this but I was going to make a blue one when my leds get here. I'll post working code this week if you want.
Thank you so much for your response Burt !!
Perhaps this may be helpful then and save double work, i have downloaded and attached the unique files on this thread asm/schematics.
If you can point me in the right direction id really appreciate it, id like to make a few boards/cubes as gifts for some close people.
Pete
  • 3x3x316f628a.asm
    3x3x316f628a.asm
  • LED.asm
    LED.asm
  • new3x3x316f628a.asm
    new3x3x316f628a.asm
This will work
PORTA.2 turns on layer1
PORTA.6 turns on layer2
PORTA.7 turns on layer3
PORTB 0 to 7 are led's 1 to 8 and PORTA.3 is led 9
*Layer sink with a npn and portb sources the power to the Leds.
And this asm
Much Appreciated Burt !!
Does the schematic look right to you corresponding to the code given ?
Pete
Pete, could you write the values of all the external components Please.
Thank you.
Regards,
kv
I used 150 ohm on the leds and 1k on the npn
I looked on the other schematics and I think I got that part, I just wanted all the Values displayed on the final to make it easier to read, What value was C2 on VSS? I really like the 2 drawings in Post # 293
