3d in projection TV
zachtheterrible
Active Member
A friend of mine told me that his projection had a TV that has the symptom of being "3D", it sounded like this is a well known symptom, and that it wasn't just his interpretation. Apparently, the red green and blue are not lining up, so there are three different pictures in different colors.
What part needs to be replaced/fixed?
How hard is it to fix this?
It might just need adjusting, it's called 'convergence setup', in the olden days ALL colour TV's needed those adjustments doing - now almost all TV's use precision pre-aligned tubes (with the exception of the Sony Trinitron).
CRT type projection TV's (like the one you're talking about), have three small independent tubes, one for each colour - you need to align them so the pictures are on top of each other.
With most projection sets it's done from the remote control, and is often a customer adjustment - see if you can find the instruction book?.
