Firstly ... hi everybody,
i have a bit of an odd question regarding LEDs and a wall powered power source.
Basically... its for a friend who has asked for 3 "LED baseball hat lights" ( **broken link removed** ) to be wired up to a mains power source.
the "led cap lights" consist of 5 leds (super white, probably 3.3v and 25ma), these were initially powered by 2 X CR2032 batteries in series with output at 3v so i guess its a 6v to power leds.
From here on i will call each bank of 5 leds a set... so there are 3 sets of lights.
the 3 sets have already been wired together by a friend who said we only need to connect to a power source. (he said 9v... i think it should be 6v)
see picture of the internal (on spare) showing that the leds are wired in parallel...
there are two wires.. red and black... these are soldered onto the battery terminals on the sets...
set 1 has two red connected to positive, one leads to set 2 positive and the other is connected to the power supply positive. the black is connected in same way but to negatives.
set 2 is connected to set 3 with the red (positive) going to positive terminal and black to negative. (and previously mentioned connections).
set 3 ONLY has the connections to set 2 with red for positive and black for negative.
my questions are:
any help on this would be greatly appreciated.
please dont say to rebuild as this is just for prototype and so i will make a proper set of banks for friend (where i know more of what im doing, and resistor for each led!), we just need this working asap!
once again any help would be great as i just cant work this one out!
thanks
kielo
my questions are:
- is this correct wiring?
- if i have a power supply of 6v (switch-able upto 12v) dc (max out 1.5 amp) will i need a resistor in place? i was told not but the leds blew! but i was also told to set at 9v...
- if i do need resistor where should it go? as it seems a mix of parallel and series
thanks
kielo
