The question really makes no sense, it's the circuit that controls the operation, not the transistor itself - as a silicon transistor the turn-on threshold is around 0.7V, as with all single bipolar silicon transistors.hello,
i have question of whether the input to 2n3904 can be like 2V? is there some input voltage range for 2n3904?
thank you
ControversialAs a bipolar is a V controlled device,
We need a schematic. To get 2V at the input there must be a resistor on the emitter. Need more infornation.i have question of whether the input to 2n3904 can be like 2V?
That is the max allowed reverse voltage where the junction begins avalanche breakdown.The B-E junction can supposedly tolerate 6V.
hFE is used when the transistor is an amplifier with plenty of Vce. Then it is not saturated.The Gain (Hfe) in combination with the maximum C-E Current is what you want to look at. unfortunately the Hfe can typically range from 100 to 400 and vary wildly from transistor to transistor.
When a transistor is saturated then the datasheet shows a base current that is 1/10th the emitter current.
Not very controversial when you do measurements.Controversial
Transistors are generally considered current controlled devices, and FET's are voltage controlled.
