26 bits wiegand encode problem
helloleong
Hi, im writing c-code to receive the 26 bits wiegand data in pulse wave form. PIC16F272, MPLAB IDE v8.50, MPLAB in circuit debugger ICD2, Hi-Tech ANSI C Compiler. And im using the PORTB interrupt to detect the card as the code below.
unsigned long int EMCardNo;
void interrupt isr(void)
        CLRWDT();   //Clear watchdog timer
        //----- PORTB Interrupt -----//
	if (RBIE && RBIF && 0x30) //Mask off other bits
                temp=PORTB;  //Read PORTB
                temp&=0x30; //Leave only the necessary bit
                if(temp && 0x20) //D0=0
		     EMCardNo=0;
		     EMCardNo=EMCardNo<<1;
		     EMCardNoCounter++;
                else  //D1=0
                     EMCardNo=1;
		     EMCardNoCounter++;
		RBIF = 0; //Clear interrupt flag
		Delay_Routine(6); //Wait until pulse end 50usec
RB5 is D0
RB4 is D1
The problem was when I sawp the card the module did generate 26 bits, but the PIC software only could capture until 6 bits. Im using the watch window and run to watch the bits. Something weird happen, when i change the EMCardNo to unsigned long int the counter at watch window didnot change at all but the EMCardNo did change its value, but the value was is not consistent for the same card.
And when i change to unsigned char, the EMCardNo and counter did change its value but not consistent also.
Did anybody face this problem before? Does it got to do with the c-compiler library? And how can i check on the simulator timing for the if condition to run how many sec?
Thanks everybody.
Pommie
Most Helpful Member
As the RB interrupt is edge triggered there is no need to have a delay in the ISR and this could be causing your problem.
Also, the lined if (RBIE && RBIF && 0x30) is if (bool && bool && true) and so the last term is redundant.
Not knowing what wiengand is and unable to google it, how do you know when one set of bits ends and another begins?
helloleong
Hi, Mike. Thanks for your reply. At first im doin using polling base, but the pic cannot enter the if statement.
So I change to interrupt base by refering this Old Nabble - PIC - [PIC] - Wiegand decoding and reading
Thanks for your remind for if (RBIE && RBIF && 0x30), im trying to mask of other bit of portb, because other pin will use as capasitive sense button.
I do not want other pin trigger to enter this if statement.
The reader of 26bit wiegand will generate a 0 pulse when the card swap to the reader by 2 data line D1 and D0.
D1 and D2 will always stay high. When a card present, D1 and D0 will generate 0 pulse, D1=1, D0=0. And D1 and D0 will not generate 0 pulse at the same time.
Did anyone use MPLAB with Hi-tech C free version. I heard got alot of problem when compile.
Pommie
Most Helpful Member
May I suggest a few changes to your code. By doing a bit of logic you can work out which bit caused the IOC interrupt to fire.
This code does that,
        changed=temp^previous;    //find only pins that have changed
        newhigh=changed&previous; //and have gone from low to high
        newlow=change&(~previous);//find pins that are new lows
        previous=temp;
After the above code newhighs will have a bit set for each pin that went from low to high and newlows from high to low. This eliminated the need for the delay.
So, your code would now look like,
unsigned char previous;
unsigned char changed,temp,newlow,newhigh;
    if (RBIE && RBIF)    //Mask off other bits
        RBIF=0;          //clear interrupt
        newlow=changed&(~previous);  //find pins that are new lows
        previous=temp;
        if(newlow & 0x20) //D0 went low
             EMCardNo=0;
             EMCardNoCounter++;
        if(newlow & 0x10) //D1 went low
             EMCardNo=1;
             EMCardNoCounter++;
Note that in your original code you had if(temp && 0x20) which will test if temp is none zero. To test bit 5 it should be if(temp & 0x20).
helloleong
Thanks Mike, Now i have put a test port to test does it go into the PORTB interrupt. But it does not get in to it when i swap card.
GIE = 1; //Global Interupt Enable: Enables all unmasked interrupts
RBIE = 1; //Enables the PORTB change interrupt
RBIF = 1; //None of the PORTB general purpose I/O pins have changed state
I did set the PORTB interrupt bit as above, did i miss any thing? Still the same is PIC16F272.
Pommie
Most Helpful Member
It's almost impossible to find problems with snippets of code. However, only pins that are digital inputs can trigger the interrupt.
Also, there is no such chip as a 16F272.
helloleong
Thanks Mike! :)
After i test the interrupt by adding test port. The below codes works, and able to capture the data constantly with the same card.
And i also disable all the interrupt to test the PORTB interrupt only.
RBIF = 1;	//Set interrupt flag (should be not set, but the MCU does not set it self when interrupt)
volatile unsigned long Wiegand=0;
volatile unsigned char WieCounter=0;
	if (RBIE && RBIF && (~PORTB & 0x30)) //mask off bits other than D0&D1 (RB5&RB4)
		//RE2 = 0; //test port
		tempB = PORTB;
		tempB &= 0x30;
		if(tempB & 0x20) //D0 detect 0
			Wiegand = Wiegand << 1;
			WieCounter++;
			while(D0==0||D1==0){CLRWDT();} //Signal only capture once (delay)
		else //D1 detect 0
			Wiegand |= 1;
			WieCounter++;
But, now another problem arise. The watch window value keep on display Reserved Memory for the Wiegand as i assigned it as volatile unsigned long Wiegand=0;
Card Number 119,09292 (Decimal) - 02EE4899 (Hex)
Result:
Varieble Name Value
unsigned char 0x99
unsigned int 0x4899
unsigned short long Reserved Memory
unsigned long Reserved Memory
I search from the internet found the register place in the reserved register for debugger. How can i set to another register address?
Thank you so much.
helloleong
Thanks for everybody who help. Finally Done, will post the code here. Hope it will help other people as well.
Compiler : Hi-tech V9.70 V9.70 (PRO Mode) Trial version
IDE : MPLAB IDE V8.50
Debugger : MPLAB ICD 2
Device : PIC16F727
volatile unsigned char tempB=0;
// Initialize for PORTB Interrup-on-change
IOCB = 0b00110000;	// Interrupt-on-change enable for bit4 and 5
RBIE = 1;		// Enables PORTB change interrupt
RBIF = 0;		// Clear PORTB interrupt flag
	if (RBIE && RBIF && (~PORTB & 0x30)) 	// Mask off unnecessary bit
	{   CardDetected(); }			//END: PORTB Interrupt
	//----- Other TMR0 Interrupt -----//
	if (T0IE && T0IF){
	//RD7=0; //Test port led
	 ..//If your other interrupt cause more than 50us, call again the CardDetected() Function
void CardDetected(void)
	//RE2=0; 				//Test Port LED
	T0IE = 0;				//Disable other Timer0 Interrupt
	tempB = PORTB;			//Read PORTB
	tempB&= 0x30;			//Mask off unnecessary bit
	if(tempB & 0x20) 			//DO detect 0
		WieCounter++;
		while(D0 == 0 || D1 == 0); 	//Wait until D0 return to 1
		if(WieCounter == 26)
			T0IE = 1;		//Enable other Timer0 Interrupt
			Wiegand = Wiegand & 0x03FFFFFF; //Mask off unnecessary bit
                                                WieCounter = 0;
	else 				//D1 detect 0
		Wiegand |= 1;
		WieCounter++;
		while(D0 == 0 || D1 == 0); 	//Wait until D1 return to 1
			T0IE = 1; 		//Enable Timer0 Interrupt
                                                WieCounter = 0;
	} RBIF = 0;
EE World Online Articles
Loading
