Try 10 turns of 10 or 12 AWG wire around, or near, the switch. It carries the water heater current, 20 or 30A.thanks. can you help me with setup? A 230V water heater element (10 gauge solid wire) when powered will close the switch, grounding a mV circuit.
Will a parallel stranded wire work for the electromagnet, and can I be sure the reed switch is sensitive enough to switch?
I picked up both a reed switch and a 230V relay (I plan to also switch a 110 circuit). Just to verify --
the relay is 32500 ohm, rated 230V across the coil. I plan to connect it with 18 AWG wire across the 2 heating element terminals. Yes I will be careful. I don't think anything will pop, but little plastic parts with large voltages scare me. Is it OK?
Is the aircon unit an evaporative unit, or a refrigeration unit? If it is evap, then running dry wont hurt it; it just wont cool.Another question on a similar topic...
