200 steps motor rotation
Nagarathna
project: i have interfaced 89S52 microcontroller and servo motor using l293d driver ic.
I want the motor to rotate at 200 steps to make one complete revolution i.e 1.8 degree.
problem: l293d ic is getting heated and i am getting only 200 steps.
this my code:
sbit EN1 = P2^7;
sbit 1a = P2^6;
sbit 2a = P2^5;
sbit EN2 = P2^4;
sbit 3a = P2^3;
sbit 4a = P2^2;
main()
1a=1; 2a=0; 3a=0; 4a=0; // 1000
delay_msec(1000);
1a=1; 2a=0; 3a=1; 4a=0; // 1010
delay_msec(1000);
1a=0; 2a=0; 3a=1; 4a=0; // 0010
delay_msec(1000);
1a=0; 2a=1; 3a=1; 4a=0; // 0110
delay_msec(1000);
1a=0; 2a=1; 3a=0; 4a=0; // 0100
delay_msec(1000);
1a=0; 2a=1; 3a=0; 4a=1; // 0101
delay_msec(1000);
1a=0; 2a=0; 3a=0; 4a=1; // 0001
delay_msec(1000);
1a=1; 2a=0; 3a=0; 4a=1; // 1001
delay_msec(1000);
You mean a stepper motor, not a servo motor. They do require constant current in either one or two phases at all times, even when standing still. What current does the motor require for each phase? Being too hot to touch is OK as long as the junction temperature is below the 150 degrees C typical maximum. Certainly too hot to touch without getting a nasty burn.
You wanted 200 steps, you are getting 200 steps, what is the problem?
Chip may be hot because you are taking too much power. Look at the spec sheet for the chip and motor.
I have a stepper motor clock **broken link removed** and I always turn off the power when not moving the hands. Runs fine, for months.
Constant current drive is not a requirement, but does result in better motor performance. It is sometimes done with a higher voltage than the motor requires, then inserting a dropping resistor. I often drive with out it.
You can of course get constant current with fancy pwm, chopping.... circuits.
stepper motor steps and degree
I want the motor to rotate at 200 steps to make one complete revolution i.e 1.8 degree.how to get them?
problem: l293d ic is getting heated and i am getting only 40 steps.
this is my code:
sbit EN1 = P2^7;
sbit 1a = P2^6;
sbit 2a = P2^5;
sbit EN2 = P2^4;
sbit 3a = P2^3;
sbit 4a = P2^2;
main()
delay_msec(1000);
delay_msec(1000);
delay_msec(1000);
delay_msec(1000);
delay_msec(1000);
delay_msec(1000);
delay_msec(1000);
delay_msec(1000);
Hai
Reduce the delay time, it is the problem
Try reducing below 100ms
Regards
Nandhu
I do not think it is the delay time, steppers can run infinitely slowly. That aside the delay function may need to be called with an unsigned char. It is in some compilers.
As arhi said, the poster hasn't given us enough of his code to determine what's going wrong. The code he listed only a snippet.
