1wire simualtion with oshon?
SwingeyP
Does anyone have a plugin for oshon that will simulate 1wire comms?
Is there any other way of doing it? - If not does the following code make sense?
Sorry lots of questions there but i hope you'll get the idea.
<code>
'lcd program written by paul swingewood
'June 2010
AllDigital
Define LCD_BITS = 8
Define LCD_DREG = PORTB
Define LCD_DBIT = 0
Define LCD_RSREG = PORTA
Define LCD_RSBIT = 0
Define LCD_EREG = PORTA
Define LCD_EBIT = 2
Define LCD_RWREG = PORTA
Define LCD_RWBIT = 1
Define LCD_READ_BUSY_FLAG = 1
Define LCD_COMMANDUS = 5000 'delay after LCDCMDOUT, default value is 5000
Define LCD_DATAUS = 100 'delay after LCDOUT, default value is 100
Define LCD_INITMS = 20
Define 1WIRE_REG = PORTA
Define 1WIRE_BIT = 3
Dim menucode As Byte
Dim gait As Byte
Dim speed As Byte
Dim mode As Byte
1wireInit
WaitMs 1
1wireGetByte menucode
startup:
Lcdinit LcdCurBlink
Lcdcmdout LcdClear
1wireInit
WaitMs 1
start:
1wireGetByte menucode, gait, speed, mode
Select Case menucode
Case 1
Gosub mainmenu
Case 2
Gosub runmenu
Case 3
Gosub setupmenu
EndSelect
Goto start
End
mainmenu:
Lcdcmdout LcdLine1Pos(3)
Lcdout "INSECT-A-BOT"
Lcdcmdout LcdLine2Home
Lcdout "RUN SETUP DEMO"
Return
runmenu:
Lcdout "GT"
Lcdout #gait
Return
setupmenu:
Lcdout "GAIT SPEED MODE"
Return
</code>
Have you run the code in Oshonsoft.?
I write modules for the Sim, never had need for a 1wire module.
What device are you using as the 1wire source.?
Hello again Eric. This all stems from my robot project. The idea is to have a pic which I will call the 'brain'. The brain will get inputs from a set of switches and send a 1 wire communication to the lcd control pic. This pic will really just store the different menus, error messages, and anyting else I can think of. It's a bit of an overshoot but it all fits in with the idea of multiplexing several modules to a common bus further down the page.
In answer to your question. Yes I tried it in oshon and it all works if I set the values like
start:
menucode = 2
gait = 3
speed = 2
mode = 3
Case 1
Gosub ma
I just wondered if there was a way of simulating what comes on that 1 wire comms. I was just about to wire to pics togethor on some vero board and try that to see what happened. The brain pic just sending random 1wire messages which should then be picked up by the lcd control pic. I hope all this is making sense.
Regards - Paul
hi Paul,
What is the 1wire sender type number.?
Your code looks ok, its in line with what the Oshonsoft manual says for the 1wire Basic
Hi Eric, It will just be another PIC. Probably a 16f876A for the brain. This pic will send 1wire comms and the other pic (LCD module) will recieve it. There is no need (at the moment) for handshaking. I hope you get the idea now. One pic (brain) sending a 1wire comms to another pic (LCD module) - The code above uses PORTA.3 for receive so I guess I could use the same on the other pic but any pin will do.
Ok I gave up on the 1wire and decided to go for serin/out. I never knew you could make this work on any pin. I have to say pic basic makes life a lot easier at times. This is what I have -all working.
BRAIN CODE
AllDigital
Config RA0 = Input
Config RA1 = Input
Config RA2 = Input
Config RA3 = Input
Config RA4 = Output
Config RA5 = Output
Config PORTB = Output
Config portc = Output
Define SEROUT_DELAYUS = 5000
start:
Serout PORTB.7, 4800, 1, 0, 0, 0
WaitMs 2000
Serout PORTB.7, 4800, 2, 1, 2, 3
WaitMs 2000
Serout PORTB.7, 4800, 3, 0, 0, 0
WaitMs 2000
Goto start
End
LCD MODULE CODE
'June 2010
AllDigital
Define LCD_BITS = 8
Define LCD_DBIT = 0
Define LCD_EBIT = 2
Dim gait As Byte
Dim speed As Byte
Dim mode As Byte
startup:
Lcdinit LcdCurBlink
Lcdcmdout LcdClear
1wireInit
WaitMs 20
gait = 0
speed = 0
mode = 0
start:
Gosub getdata
Case 1
Gosub mainmenu
Case 2
Gosub runmenu
Case 3
Gosub setupmenu
EndSelect
Goto start
End
getdata:
Serin PORTA.3, 4800, menucode, gait, speed, mode
WaitMs 500
Return
mainmenu:
Lcdcmdout LcdLine1Clear
Lcdcmdout LcdLine2Clear
Lcdcmdout LcdLine2Pos(2)
Return
runmenu:
Lcdout "GT"
Lcdcmdout LcdLine2Pos(4)
Lcdout #gait
Lcdcmdout LcdLine2Pos(6)
Lcdout "SPD"
Lcdcmdout LcdLine2Pos(10)
Lcdout #speed
Lcdcmdout LcdLine2Pos(12)
Lcdout "MDE"
Lcdcmdout LcdLine2Pos(16)
Lcdout #mode
Return
setupmenu:
return
As always many thanks for the help.
hi Paul,
If you move the serin to PORTA.4, [tmr0] you can use ON INTERRUPT for the serial in.
Code fragment.
Dim gait As Byte
Dim speed As Byte
Dim mode As Byte
OPTION_REG = 0x30  'tmr0, ext clock,high to low,
INTCON.TMR0IE = 1  'set tmr0 interrupt
INTCON.TMR0IF = 0  'clear an existing tmro flag
TMR0 = 0xff  'load timer0 with 255, intr on next high to low
startup:
Lcdinit LcdCurBlink
Lcdcmdout LcdClear
gait = 0
speed = 0
mode = 0
Enable  'enable interrupts
'for my use only
Serout PORTA.2, 4800, "OK", CrLf  'for serial tx test only
start:
Case 1
Gosub mainmenu
Case 2
Gosub runmenu
Case 3
Gosub setupmenu
EndSelect
menucode = 0
Goto start
End
'you may want to add save system
On Interrupt
getdata:
INTCON.TMR0IF = 0  'clear inter flag
Serin PORTA.4, 4800, menucode, gait, speed, mode
TMR0 = 0xff  'reload tmr0 with 255
Resume
Many thanks for that Eric. Interupts were something in the back of my mind for a while. I'm going to have a readup and see how they can improve further code i've written.
