1n4001
Like most silicon diodes, the 1N400x series will drop approximately 0.7volts when conducting in the forward direction.
Yikes, anything else I can use instead to acheive the same effect but use up less volts - thats a lot of volts to take from my solar cell arrangement!
Peter
Look at the datasheet, the forward voltage drop varies a lot with the current.
Peter
You could try a schottky diode (I dont know any type numbers off the top of my head), these have a forward volt drop of about 0.2 volts.
I think a 1N5817 also is a schottky diode
Also try some type of germanium diode(1n34)...these will drop
approx 300 millivolts.....but double check the current rating and
make sure it will handle your requirements.
Bear in mind, germanium diodes are VERY leaky, it's going to let your batteries discharge back through the panel (although slowly).
Many solar panels already have diodes built-in, it would be worth checking to see if these ones do?. But so far there's no mention of even what spec the panels might be? (or the batteries).
Thanks guys, just the info I need. Will get a 1N5817 - looks perfect.
Peter
