Jon Wilder
Active Member
Hi all.
When using the MSSP module as I2C master, I always send the start, restart, ack/nack, and stop bits by setting the appropriate control bit in SSPCON2, then polling the control bit to wait for the completion of the start,restart,ack/nack, and stop bits. Each time the cycle completes, my code then clears the SSPIF flag in PIR1.
However, when sending data, I write data to SSPBUF, then poll the SSPIF flag in register PIR1.
Sending the start,restart,ack/nack, and stop works perfectly fine so I know the hardware is working and initialized properly. However, when writing data to SSPBUF, the SSPIF flag never sets, hence my code hangs forever since the flag never gets set. I am not using interrupts.
The I2C slave component is a 24LC64 EEPROM chip, which I've worked with many times in the past without issue (even using the SSPIF polling routine when sending data) with 470R pull up resistors on the SCL/SDA bus. The chip is interfaced with MSSP1 on pins RC3 and RC4.
What could be causing this issue?
void sendI2C(uint8_t data){
while(SSPCON2 & 0b01011111); // wait for idle state
SSPBUF = data; // send data
while(!PIR1bits.SSPIF); // wait for send to complete
PIR1bits.SSPIF = 0; // clear SSPIF
void initI2C(void){
SSPSTATbits.SMP = 1; // disable slew rate control
SSPADD = 0x9F; // 100kHz bit rate (Fosc = 64MHz)
ANSELC &= 0b11100111; // RC3-RC4 digital I/O mode
TRISC |= 0b00011000; // RC3-RC4 open drain for SCL/SDA
SSPCON1 = 0b00101000; // enable MSSP1, I2C master mode
* The following code works with no issues - example of how control bits are handled
void sendStartBit(void){
SSPCON2bits.SEN = 1; // send start bit
while(SSPCON2bits.SEN); // wait for send to complete (SEN cleared by hardware)
