16F886 Bug in proteus ISIS
Mosaic
FYI there seems to be a bug in the ISIS setup of the ADCON1 register on the Vref+. It seems that the ADC Vref+ and Vref - bits are interchanged in the sim. Therefore in order to activate Vref+ /RA3, instead of ADCON1,4 being set. U must set ADCON1,5.
Can anyone please independently verify this bug?
The errata spec sheet does not discuss this so it must be an ISIS (7.8 sp2)issue.
I'm running version 7.9 dlls & models. I think the oldest ISIS I had was 7.4.....will have to look for it.
Hmm found another bug:
T1con.7 =1 shows active gate inversion as in timer gate triggers when c2out is LOW. This should be timer gate triggers when c2out is HIGH. Verified by the virtual oscilloscope in ISIS and a T1con watch variable.
When I do the physical prototype I'll verify what works precisely and whether the data sheet or ISIS is at fault.
