16f676 to 16f72 conversion
sahu
i'm trying volt meter code conversion 16f676 to 16f72 step by step . use CCS C
16f676 code as
#include <16F676.h>
#device adc=10
#fuses INTRC_IO,NOWDT,PUT,NOPROTECT,BROWNOUT,NOMCLR
#use delay (clock=4000000) // 4MHz clock
#rom  0x3ff={0x3444}
#byte PORTA = 0x05
#byte PORTC = 0x07
#byte TRISA = 0x85
#byte TRISC = 0x87
#define SPORTA PORTA
#define SPORTC PORTC
#define  TICKS_BETWEEN_INTERRUPTS      5000 //5000
#define  INTERRUPT_OVERHEAD            35
#define  TMR1RESET (0xFFFF-(TICKS_BETWEEN_INTERRUPTS-INTERRUPT_OVERHEAD))
const char SegCode[11] = {0x40,0x57,0x22,0x06,0x15,0x0C,0x08,0x56,0x00,0x04,0xFF};
	//                  0    1    2    3    4    5    6    7    8    9
const char Column[3]   = {0x02,0x01,0x04};
static char Segment[3] = {0x7f,0x7f,0x7f};
static unsigned char ColCount=0x00;
void CPU_SETUP(void);
void Display(void);
void HTO7S(unsigned int32 Num);
byte i;
unsigned int32 result;
#INT_TIMER1
void Timer1(void)
	set_timer1(TMR1RESET);
	Display();
void main()
	unsigned char i;
	CPU_SETUP();
	while(true)
		result=0;
		for (i=0;i<20;i++)
			set_adc_channel(3);
			delay_ms(1);
			result=result+read_adc();
			//result = 0x3fe;
	 	HTO7S(result/20);
		delay_ms(200);
void CPU_SETUP()
   setup_comparator(NC_NC_NC_NC);	// not use comparator module
   setup_adc_ports( sAN3 | VSS_VDD);
   setup_adc(ADC_CLOCK_DIV_64);
   TRISA=0b00011000;
   PORTA=0x27;
   TRISC=0b00000000;
   PORTC=0x37;
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
   enable_interrupts(GLOBAL);
   enable_interrupts(INT_TIMER1);
// Display routine
void Display()
	PORTA = 0b00100111;	  // off all digits column and Segment G
	PORTC = 0b00111111;   // off segment a-f
	delay_cycles(2);
	if (ColCount>=3)
	ColCount=0;
	SPORTC = Segment[ColCount];
	SPORTA = ((Segment[ColCount] & 0b01000000)>>1) | (Column[ColCount]^0x07);
	ColCount++;
// Convet HEX 2 byte to 7-Segment code
	unsigned int32 res;
	Segment[0]=SegCode[30*Num/10230];
	if (Segment[0]==0x40)
	Segment[0]=0xFF;
	res = 30*Num%10230;
	Segment[1]=SegCode[10*res/10230];
	res=10*res%10230;
	Segment[2]=SegCode[10*res/10230];
1st of all trying understand
7seg. aregment
676 as
i want 72 as
	Ues 7 Segment Common Anod
	PORT RB7 = A
	PORT RB6 = B
	PORT RB5 = C
	PORT RB4 = D
	PORT RB3 = E
	PORT RB2 = F
	PORT RB1 = G
	PORT RB0 = Display 1
	PORT RC7 = Display 2
	PORT RC6 = Display 3
		0= on , 1 = off
         a
       |   |b
     f | g |
       |   |c
     e |   |
         d
	______________________________________________________
PORT	|RB7	|RB6	|RB5	|RB4	|RB3	|RB2	|RB1  |
________|_______|_______|_______|_______|_______|_______|_____|
	| A	| B	| C	| D	| E	| F	| G   |
Digit
_______________________________________________________________
  1 =	  1	 0	 0	 1	1	 1	 1	=
  2 =	  0 	 0	 1	 0	0	 1	 0 	=
  3 =	  0	 0 	 0	 0	1	 1	 0	=
  4 =	  1	 0	 0	 1	1	 0 	 0	=
  5 =	  0	 1 	 0	 0	1	 0	 0	=
  6 =	  1	 1	 0	 0	0	 0	 0	=
  7 =	  0	 0	 0	 1	1	 1	 1	=
  8 =	  0	 0 	 0	 0	0	 0	 0	=
  9 =	  0	 0	 0	 0	1	 0	 0	=
OFF =	  1	 1	 1	 1	1	 1	 1	=
but confuse whats right
for exampled digit
1 = 1 0 0 1 1 1 1 = 4F Is right or
1 = 1 0 0 1 1 1 1 = 79 is right
for exampled digit
Both are not right..... you are dismissing the LSBit... so 1001111x will be 0x9E hex or 158 decimal
Thank u sir for reply 7 guide me .
as per Ur sussation
	PORT RB7 = A
	PORT RB6 = B
	PORT RB5 = C
	PORT RB4 = D
	PORT RB3 = E
	PORT RB2 = F
	PORT RB1 = G
		0= on , 1 = off
         a
       |   |b
     f | g |
       |   |c
     e |   |
         d
Digit
  1 =	  1	 0	 0	 1	1	 1	 1	= 9E
  2 =	  0 	 0	 1	 0	0	 1	 0 	= 24
  3 =	  0	 0 	 0	 0	1	 1	 0	= C
  4 =	  1	 0	 0	 1	1	 0 	 0	= 98
  5 =	  0	 1 	 0	 0	1	 0	 0	= 48
  6 =	  1	 1	 0	 0	0	 0	 0	= C0
  7 =	  0	 0	 0	 1	1	 1	 1	= 1E
  8 =	  0	 0 	 0	 0	0	 0	 0	= 0
  9 =	  0	 0	 0	 0	1	 0	 0	= 8
OFF =	  1	 1	 1	 1	1	 1	 1	= FF
now i'm doing right ?
how can manege displays ?
( PORT RB0 = Display 1
PORT RC6 = Display 3 )
The best way is to setup a interrupt to update the displays when required..... Nigel's tutorials have a multiplexed 7 segment tutorial...
See the link in my signature.
not understand . in
tutorial 10... Dual seven segment display ( common anode )
my conversion in shown fig.
What do you mean "how can manege displays ?"
How many seven segment displays have you got?
my mean how can manege displays with ( PORT RB0 = Display 1
PORT RC6 = Display 3 ).
for exampled 1 = 1 0 0 1 1 1 1
so pl give example for digit 1 , 2 & 3 management
You are using MikroC... I use XC8 or C18.... If I give you an example ( there is one in MY tutorial... 10 same as Nigel's ) but It wont work on your compiler.
Do I get from the title that you have pic16f72 ?
i'm using CCS C & PIC 16F72 , not MikroC.
in 1st post is complete code vm for 30 v dc , i want it convert 600 vac & 16f72.
also lurn step by step its function.
I'm just changing it to run on my sim... I have converted to Hi tech to see what gives.... Just trying to get the interrupt working..
Still can't get the interrupt going..... I really can't see why.... The TMR1IE is set and the GIE is set.... But when the TMR1IF goes high... It doesn't enter the ISR??????
It may be a problem with the sim or the compiler.... I think its the compiler because in the dissasembly the ISR hasn't got a REFIE command or the SWAPF to reinstate the W reg...
Digging deeper...
