16f628A int_rda interrupt problem in CCS C
kbaser
I have a cLCD driver circuit which is attached PC's Tx port directly to MCU's hardware Rx port (RB1) by a 22k only (without MAX232C ..etc)
My problem is
when I set the MCU for an int_rda interrupt and send some chars fromm PC to MCU it does not call the interrrupt void function.
Do you think that it is because of direct 22k ?
Does it run when I add a MAX232 between Pc and Mcu?
please help
thanx
My code piece ;
#int_rda
void comm_test() {
disable_interrupts(int_rda);
void main() {
enable_interrupts(GLOBAL);
while(1) {
enable_interrupts(int_rda);
actually I set
#use rs232 (baud=2400, rcv=pin_b1, INVERT)
by using invert, I can handle rs232 connections and I can see the coming data by
gets() and getch() methods in an endless while loop.
I want to use "int_rda" instead of while loop (to detect the coming data from PC)
kB
actually I set
kB
I guess you posted while I was posting. :)
your code sample doesn't show your use of getch() and you need the while loop, else your PIC will go to sleep ... which should not affect this...
EDIT: do you have the example 'EX_SISR.C' in your examples directory?
//// EX_SISR.C ////
//// This program shows how to implement an interrupt service ////
//// routine to buffer up incomming serial data. ////
Hi again,
I tried ex_sisr.c example unfortunately I can not handle the int_rda interrupt.
Please check my simple code (with no int_rda) which works well below ;
#include <16F628A.H>
#fuses INTRC_IO, NOWDT, NOPROTECT, PUT,NOMCLR,NOBROWNOUT
#use delay(clock = 4000000)
#include "flex_lcd420.c"
char data[20];
void main() {
lcd_init();
while (TRUE) {
gets(data);
printf(lcd_putc,data);
and here is the code pieces which I added to ex_sisr ;
#int_rda
void serial_isr() {
int t;
//added to blink on interruption
output_low(pin_b0);
delay_ms(1000);
output_high(pin_b0);
void main() {
//added to blink on startup
output_low(pin_b0);
delay_ms(1000);
// #if defined(__PCD__)
// enable_interrupts(intr_global);
// #else
enable_interrupts(global);
// #endif
In the second example I see led blinking in main(), but no blinking in serial_isr() during serial data send.
Please help why this hardware usart doesn't work but software working ?
kB
Your problem is here:
#int_rda
void serial_isr() {
int t;
delay_ms(1000);
kB
A one second blocking delay in an interrupt is asking for trouble. Interrupts should be as short as possible.
You should put the second delay in your main line code
Okay, I remove the
delay_ms(1000);
lines in interrupt. I just left
output_low(pin_b0);
line. But unfortunately I can see nothing during serial data transfer.
I mean this interrupt is never caught during serial data transfer.
Does anybody tried "int_rda" interrupt working with direct connection from Pc(tx) to 16F628A(rx) through 22k (no MAX232 IC) ?
Okay, I remove the
delay_ms(1000);
output_low(pin_b0);
I have never tried with out using a max chip, and it has been a long time since I've used ccs c.
The problem may be that you need to define both a receive and transmit pin. Try it this way:
#use rs232 (baud=2400,xmit=PIN_B2, rcv=pin_b1, INVERT)
