I am trying to figure out the right way to implement my ideas, but I am getting stuck.
I have a Motorcycle Trunk which I added LEDs to. I used 3 arrays, each array consisting of 6 leds and a resistor in series. One array is for the Left Turn, one for Right Turn, and one for Middle/Brake.
I would like:
PWM power to all 3 circuits if Brake is not applied and turn signal is not activated
PWM power to center and left, if the right signal is activated...same for right side if left is activated.
I would like to go full power to all lights (remove PWM) if brake is activated.
The last part is the hardest. If the turn signal is activated, I get an On-Off power source from the turn signal wiring. I want this to flash the left or right sides, and I want the side to go out(not PWM low) when in the "off" cycle...I imagine I need some sort of timer to see if that source has been high in the last 3 seconds or whatever?
Any info I didn't provide? LED are common 2.1V, 20mA red LEDs. 47 ohm resistor was used, 13.5 volts the usual source (may be as low as 12.6)
I would like:
