16F628A Code Problem
Number17
Hi
I've started using my pics today again, after about 2 months. I've compiled a small program just to refresh my memory again. Its a simple flashing led. It works fine, but when I add the command BTFSS it seems that the pic gets stuck there. No matter what I do, I can't get the pic to read the status on a port. The pic react as if the switch is open. I've added a 10k from the supply to RA0, and the switch from RA0 to ground.
Any help would be great
Here's the code
; INCLUDE PIC16F628A
LIST 		P=16F628A
INCLUDE 	<P16F628A.INC>
__CONFIG	_BODEN_OFF&_CP_OFF&_PWRTE_OFF&_WDT_OFF&_XT_OSC&_LVP_OFF&_MCLRE_OFF
ERRORLEVEL	-302
ERRORLEVEL	-203
; GENERAL REGISTERS
CBLOCK
COUNT1
COUNT2
ENDC
; SETUP THE I/O PORTS ETC
BSF		STATUS,5H
MOVLW	B'01'
MOVWF	TRISA
BCF		STATUS,5H
CLRF	PORTA
; START
START
BTFSS	PORTA,0
GOTO	START
BSF		PORTA,1
CALL	DELAY
BCF		PORTA,1
CALL	DELAY
GOTO	START
; SUBROUTINES
DELAY	DECFSZ	COUNT1
		GOTO	DELAY
		DECFSZ	COUNT2
		GOTO	DELAY
RETURN
END
You have set AN0 as an analog input.:)
Hi
Thanks I forgot about the comparators. I've added these 2 lines before the setup of the I/O according to the datasheet.
MOVLW	0X07
MOVWF	CMCON
Now its works perfect.
What I don't understand though, is that I never really added those lines to the program before, yet it still worked most times.
Hi
MOVLW	0X07
MOVWF	CMCON
Did you always use AN0 or another ANx.?
Which part of RSA are you from.?
Hi
No, I'm still a noob. I learned from a tutorial that used a 16F84, so there were no analog pins. I had to read the datasheet about the comparators. I tried to get hold of a 84, but they were just to expensive, so I brought a 16F628A.
I was born in the Freestate, but now I live in Guateng. ( This is also why my english is bad, because my home language is Afrikaans. )
So you should - check my tutorials which use the 628 instead of the long obselete 84.
When I first started, I didn't know of your tutorials. In the time passed I saw them, but I never really looked at it. I'll check them out.
Thanks.
Just something quick, what does that sign in your avatar mean?
In your code you should change cblock to cblock 0x20 or you will have problems when you add more variables.
Hi Mike,
So what actually happens if you use cblock on it's own?, I've never considered doing it, or thought anyone ever would.
cblock [expr] label[:increment][,label[:increment]]endc
expr indicates the starting value for the first name in the block. If no expression is found, the first name will receive a value one higher than the final name in the previous cblock. If the first cblock in the source file has no expr, assigned values start with zero.
I believe it defaults to 0x00, so the 2 registers he was writing to are INDF and TMR0... Kinda scary. :)
Hey Nigel, if your avatar is "art" and not "gentle art"... Does that mean you are into the NOT-gentle form of Ju Jitsu??? :eek: :D
(edit) Darn gazumped by geko in <60 seconds... :(
The error given by MPLAB is,
Message[313] : CBLOCK constants will start with a value of 0.
So basically your variables will occupy the same area as INDF, TMR0, PCL etc.
Bad news :D
Like I said, it's not something I would ever have thought of doing, and can't concieve of anyone else doing so.
even the code is not formatted properly, and perhaps has to look like this
	LIST 		P=16F628A
	ERRORLEVEL	-302
	ERRORLEVEL	-203
; GENERAL REGISTERS
	CBLOCK 0x20
COUNT1
COUNT2
	ENDC
	BSF		STATUS,RP0
	MOVLW	0x01
	MOVWF	TRISA
	BCF		STATUS,RP0
	CLRF	PORTA
        ORG         0x00
; START
START
	BTFSS	PORTA,0
	GOTO	START
	BSF		PORTA,1
	CALL	DELAY
	BCF		PORTA,1
	CALL	DELAY
	GOTO	START
; SUBROUTINES
DELAY	DECFSZ	COUNT1,F
		GOTO	DELAY
		DECFSZ	COUNT2,F
		GOTO	DELAY
	RETURN
	END
Once we defined Include file, the CBLOC should be started properly< I thought . Should we define it, still ?
I would have thought so, why wouldn't you?.
I have followed your earlier comments and added that CBLOC starting address. At that moment , what was important for me was to indicate the OP that he did not have proper format. thus my doubt still remains, whether the include would not take care of start of user definitions? and whether the user still needs to provide the CBLOC start point ( as this is controller dependent).
