16C84 program into 16F84 (for Propeller clock)
Guillecba
Hi everyone. I am new in this excellent forum. I speak a little english, so I go
directly to my question.
I'm building a "propeller clock" from this website:
This proyect is based on 16C84. I have the 16F84 but don't work. I supose that the problem is the code in the follows instructions:
tris PORTB
tris PORTA
option
The source code link:
Thanks!
It's just the config line that's missing.
I think this will work but you may have to change it to 16F84A.
; mclock8.asm
; "The Propeller" mechanically scanned LED clock
; some changes since last version -
; modified table etc for compatiblility with 8th LED
; watchdog timer used to ensure startup
; Bob Blick February 12, 1997
; Licensed under the terms of the GNU General Public License, www.gnu.org
; No warranties expredded or implied
; Bob Blick February 18, 2002
		list	p=16F84
		radix	hex
		include	"p16F84.inc"
		[COLOR="Red"]__config   _XT_OSC& _WDT_ON& _PWRTE_ON& _CP_OFF[/COLOR]
; remember to set blast-time options: OSC=regular xtal, WDT=ON
; timings all based on 4 MHz crystal
; are these equates already in the include file? someday I'll look.
w		equ	0
f		equ	1
; Start of available RAM.
	cblock	0x0C
		safe_w		;not really temp, used by interrupt svc
		safe_s		;not really temp, used by interrupt svc
		period_count	;incremented each interrupt
		period_dup	;copy of period_count safe from interrupt
		period_calc	;stable period after hysteresis calc.
		flags		;b2=int b1=minute b4=edge
		dot_index	;which column is being displayed
		digit_index	;which digit is being displayed
		hours		;in display format, not hex(01-12)
		minutes		;00 to 59
		bigtick_dbl	;incremented each interrupt
		bigtick_hi
		bigtick_lo
		keys		;key value
		scratch		;scratch value
		tick		;used by delay
	endc
; Start of ROM
		org	0x00		;Start of code space
		goto	Start
; INTERRUPT SERVICE ROUTINE
		org	0x04		;interrupt vector
Intsvc		movwf	safe_w		;save w
		swapf	STATUS,w	;swap status, w
		movwf	safe_s		;save status(nibble swap, remember)
; done saving, now start working
; clear watchdog timer to ensure startup
		clrwdt
; increment period count
		incf	period_count,f
		btfsc	STATUS,Z	;zero set means overflow
		decf	period_count,f
; 234375 interrupts every minute. Increment the bigtick each time.
		incf	bigtick_lo,f
		btfsc	STATUS,Z
		incf	bigtick_hi,f
		btfsc	STATUS,Z
		incfsz	bigtick_dbl,f
		goto	Bigtick_out
; here? bigtick has rolled over to zero and one minute has passed.
; reload bigtick and set a flag for the main counter
		movlw	0xFC		;234375 = 0x039387
		movwf	bigtick_dbl	;0 - 0x039387 = 0xFC6C79
		movlw	0x6C
		movwf	bigtick_hi
		movlw	0x79
		movwf	bigtick_lo
		bsf	flags,1		;notify Keep_time
Bigtick_out
; done working, start restoring
		swapf	safe_s,w	;fetch status, reswap nibbles
		movwf	STATUS		;restore status
		swapf	safe_w,f	;swap nibbles in preparation
		swapf	safe_w,w	;for the swap restoration of w
		bcf	INTCON,2	;clear interrupt flag before return
		retfie			;return from interrupt
; CHARACTER LOOKUP TABLE
; ignore high bit. set=LED off, clear=LED on, bit0=bottom LED, bit6=top LED
Char_tbl
		addwf	PCL,f
		dt	0xC1,0xBE,0xBE,0xBE,0xC1	;"O"
		dt	0xFF,0xDE,0x80,0xFE,0xFF	;"1"
		dt	0xDE,0xBC,0xBA,0xB6,0xCE	;"2"
		dt	0xBD,0xBE,0xAE,0x96,0xB9	;"3"
		dt	0xF3,0xEB,0xDB,0x80,0xFB	;"4"
		dt	0x8D,0xAE,0xAE,0xAE,0xB1	;"5"
		dt	0xE1,0xD6,0xB6,0xB6,0xF9	;"6"
		dt	0xBF,0xB8,0xB7,0xAF,0x9F	;"7"
		dt	0xC9,0xB6,0xB6,0xB6,0xC9	;"8"
		dt	0xCF,0xB6,0xB6,0xB5,0xC3	;"9"
		dt	0xFF,0xC9,0xC9,0xFF,0xFF	;":"
Char_tbl_end
; SUBROUTINES STARTING HERE
; clear important bits of ram
Ram_init	movlw	0x07
		movwf	keys
		movlw	0x12		;why do clocks always start
		movwf	hours		;at 12:00 ?
		clrf	minutes
		clrf	dot_index
		clrf	digit_index
		movlw	0xFC
		movwf	bigtick_dbl
		retlw	0
; unused pins I am setting to be outputs
Port_init	movlw	0x00		;all output, b7=unused
		tris	PORTB		;on port b attached to LEDs
		movlw	b'00010111'	;port a has 5 pins. I need 4 inputs
					;b0=minutes, b1=10mins, b2=hours
					;b3=unused, b4=rotation index
		tris	PORTA		;on port a
		retlw	0
; get timer-based interrupts going
Timer_init	bcf	INTCON,2	;clear TMR0 int flag
		bsf	INTCON,7	;enable global interrupts
		bsf	INTCON,5	;enable TMR0 int
		clrf	TMR0		;clear timer
		clrwdt			;why is this needed? just do it..
		movlw	b'11011000'	;set up timer. prescaler(bit3)bypassed
		option			;send w to option. generate warning.
		clrf	TMR0		;start timer
		retlw	0
; test for index in rotation and store period in period_dup
Check_index	movf	PORTA,w		;get the state of port a
		xorwf	flags,w		;compare with saved state
		andlw	b'00010000'	;only interested in bit 4
		btfsc	STATUS,Z	;test for edge
		retlw	0		;not an edge, same as last
		xorwf	flags,f		;save for next time
		btfsc	flags,4		;test for falling edge
		retlw	0		;must have been a rising edge
		movf	period_count,w	;make a working copy
		movwf	period_dup	;called period dup
		clrf	period_count	;a fresh start for next rotation
		clrf	digit_index	;set to first digit
		clrf	dot_index	;first column
; calculate a period that does not dither or jitter
; period will not be changed unless new period is really different
		movf	period_calc,w
		subwf	period_dup,w	;find difference
		btfss	STATUS,C	;carry flag set means no borrow
		goto	Calc_period_neg	;must be other way
		sublw	2		;allowable deviation = 3
		btfss	STATUS,C	;borrow won't skip
		incf	period_calc	;new value much larger than calc
		retlw	0
Calc_period_neg	addlw	2		;allowable deviation = 3
		btfss	STATUS,C	;carry will skip
		decf	period_calc	;no carry means it must be changed
		retlw	0
; change LED pattern based on state of digit_index and dot_index
Display_now	movlw	0x05
		xorwf	dot_index,w	;test for end of digit
		movlw	0xFF		;pattern for blank column
		btfsc	STATUS,Z
		goto	D_lookup_3	;it needs a blank
		bcf	STATUS,C	;clear carry before a rotate
		rlf	digit_index,w	;double the index because each
		addwf	PCL,f		;takes two instructions
D_10hr		swapf	hours,w
		goto	D_lookup	;what a great rush of power
D_1hr		movf	hours,w		;I feel when modifying
		goto	D_lookup	;the program counter
D_colon		movlw	0x0A
		goto	D_lookup
D_10min		swapf	minutes,w
		goto	D_lookup
D_1min		movf	minutes,w
		goto	D_lookup
D_nothing	retlw	0
D_lookup	andlw	b'00001111'	;strip off hi bits
		movwf	scratch		;multiply this by 5 for lookup
		addwf	scratch,f	;table base position
		addwf	scratch,f	;is this cheating?
		addwf	scratch,f	;I think not.
		addwf	scratch,f	;I think it is conserving energy!
		btfss	STATUS,Z	;test for zero
		goto	D_lookup_2	;not a zero
		movf	digit_index,f	;this is just to test/set flag
		movlw	0xFF		;this makes a blank LED pattern
		btfsc	STATUS,Z	;test if it is 10 hrs digit
		goto	D_lookup_3	;it's a leading zero
D_lookup_2	movf	dot_index,w	;get column
		addwf	scratch,w	;add it to digit base
		call	Char_tbl	;get the dot pattern for this column
D_lookup_3	movwf	PORTB		;send it to the LEDs
		movlw	0x0C		;overhead value sub from period
		subwf	period_calc,w	;compensate for overhead and set
		call	Delay		;width of digits with this delay
		incf	dot_index,f	;increment to the next column
		movlw	0x06		;6 columns is a digit plus space
		xorwf	dot_index,w	;next digit test
		btfss	STATUS,Z
		retlw	0		;not a new digit
		clrf	dot_index	;new digit time
		incf	digit_index,f
		retlw	0		;Display_now done.
; a short delay routine
Delay		movwf	tick
Delay_loop	decfsz	tick,f
		goto	Delay_loop	;w is not damaged, so Delay can
		return			;be recalled without reloading
; test for keypress and call time adjust if needed
Check_keys	movf	PORTA,w		;get port "a"
		xorwf	keys,w		;compare with previous
		andlw	b'00000111'	;only care about button pins
		btfsc	STATUS,Z	;zero set=no buttons
		retlw	0		;return
		xorwf	keys,f		;store key value
		movlw	0x64		;a fairly long delay will
		movwf	scratch		;prevent key bounces
Key_delay	movlw	0xFF
		call	Delay
		decfsz	scratch
		goto	Key_delay
		btfss	keys,2		;test "minutes" button
		goto	Inc_mins
		btfss	keys,1		;test "tens" button
		goto	Inc_tens
		btfss	keys,0		;test "hours" button
		goto	Inc_hours
		retlw	0		;must be a glitch. yeah, right!
; increment ten minutes
Inc_tens	movlw	0x0A
		movwf	scratch		;scratch has ten
Inc_tens_loop	call	Inc_mins
		decfsz	scratch
		goto	Inc_tens_loop	;another minute added
		retlw	0
; increment one hour
Inc_hours	movlw	0x12
		xorwf	hours,w
		btfsc	STATUS,Z
		goto	Inc_hours_12
		movlw	0x07		;this part gets a little sloppy
		addwf	hours,w
		movlw	0x07
		btfss	STATUS,DC
		movlw	1
		addwf	hours,f
		retlw	0
Inc_hours_12	movlw	0x01
		movwf	hours
		retlw	0
; increment the time based on flags,1 as sent by interrupt routine
; Inc_mins loop also used by time-setting routine
Keep_time	btfss	flags,1		;the minutes flag
		retlw	0		;not this time
		bcf	flags,1		;clear the minutes flag
Inc_mins	movlw	0x07		;start incrementing time
		addwf	minutes,w	;add 7 minutes into w
		btfsc	STATUS,DC	;did adding 7 cause digit carry?
		goto	Sixty_mins	;then test for an hour change
		incf	minutes		;otherwise add 1 for real
		retlw	0		;and go back
Sixty_mins	movwf	minutes		;save the minutes
		movlw	0x60		;test for 60
		xorwf	minutes,w	;are minutes at 60?
		btfss	STATUS,Z
		retlw	0		;no? go back
		clrf	minutes		;otherwise zero minutes
		goto	Inc_hours	;and increment hours
; End of subroutines
; Program starts here
Start		call	Ram_init	;set variables to nice values
		call	Port_init	;set port directions
		call	Timer_init	;start timer based interrupt
; Done initializing, start the endless loop.
Circle					;begin the big loop
; detect falling edge on PORTA,4 to determine rotary index
; calculate rotation period and store in period_dup
; compare with working period(period_calc) and adjust if way different
		call	Check_index
; check display state and change if needed
		call	Display_now
; check keyboard and adjust time
		call	Check_keys
; check minute flag and increment time if a minute has passed
		call	Keep_time
; gentlemen, that's a clock, keep it rolling
		goto	Circle		;you heard the man, get going!
		end
; end of file
This is the log file of MPASM (mclock8.err):
Warning[215] D:\AA\MCLOCK8.ASM 12 : Processor superseded by command line. Verify processor symbol.
Message[301] D:\GUILLEM\MPASM\P16F84.INC 37 : MESSAGE: (Processor-header file mismatch. Verify selected processor.)
Warning[224] D:\AA\MCLOCK8.ASM 133 : Use of this instruction is not recommended.
Warning[224] D:\AA\MCLOCK8.ASM 137 : Use of this instruction is not recommended.
Warning[224] D:\AA\MCLOCK8.ASM 148 : Use of this instruction is not recommended.
Message[305] D:\AA\MCLOCK8.ASM 175 : Using default destination of 1 (file).
Message[305] D:\AA\MCLOCK8.ASM 179 : Using default destination of 1 (file).
Message[305] D:\AA\MCLOCK8.ASM 250 : Using default destination of 1 (file).
Message[305] D:\AA\MCLOCK8.ASM 265 : Using default destination of 1 (file).
Message[305] D:\AA\MCLOCK8.ASM 296 : Using default destination of 1 (file).
mclock8.lst:
Warning[215]: Processor superseded by command line. Verify processor symbol.
00012 list p=16F84
00013 radix hex
00014 include "p16F84.inc"
00001 LIST
00002 ; P16F84.INC Standard Header File, Version 2.00 Microchip Technology, Inc.
Message[301]: MESSAGE: (Processor-header file mismatch. Verify selected processor.)
00136 LIST
2007 3FF5 00015 __config _XT_OSC& _WDT_ON& _PWRTE_ON& _CP_OFF
00016
Warning[224]: Use of this instruction is not recommended.
0061 0066 00133 tris PORTB ;on port b attached to LEDs
0062 3017 00134 movlw b'00010111' ;port a has 5 pins. I need 4 inputs
00135 ;b0=minutes, b1=10mins, b2=hours
00136 ;b3=unused, b4=rotation index
0063 0065 00137 tris PORTA ;on port a
0064 3400 00138 retlw 0
00139 ;--------
00140 ; get timer-based interrupts going
00141 ;--------
006B 0062 00148 option ;send w to option. generate warning.
006C 0181 00149 clrf TMR0 ;start timer
006D 3400 00150 retlw 0
Thanks again!
As I said, you will probably have to add an A to the processor definition,
Add,
		list	p=16F84[COLOR="Red"]A[/COLOR]
		radix	hex
		include	"p16F84[COLOR="Red"]A[/COLOR].inc"
possible the idea of designing the program moving msg. display just like Propeller clock.
thank you
csaba911
but first link is error pls correct
and Possible source code for the clock digital or analog or text or all of
Language mikro c or c to understand the idea, where I'm good in this language
thank you
csaba911
but pls Possible source code for the clock digital or analog or text or all of
