Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
Assuming you mean a DIP package, compare the pinout for the 10F, to the pinout of the 12F in the attached image.
You'll need some way of making the 10F pins match the layout of the 12F.
You could try using breadboard and short jumper wires inserted in a 8-DIP socket, then inserted in the ZIF on your programmer (assuming your programmer supports 10F devices) or if you have some stripboard, a 8-DIP socket and some header pins, you could knock up an adaptor.
Failing that, you could buy a programming adaptor from Microchip, AC163020:
I have made a stripboard adapter, but I can't find the lead for my camera. I'll do a quick mockup in mspaint and post back shortly......
OK, the view is from the top side, with the copper tracks on the bottom.
The grey section is a track-break. (the board I used already had a track-break. If using standard stripboard, you only need to create 8 breaks...4 between the socket and 4 between the header pins ....you can omit the 3 red horizontal wire links)
The blue section is a 8-DIP socket. Pin 1 is located top-left.
The red bits are wire links.
The black dots at the top are the header pins, soldered to point downwards from the copper side and fit into the ZIF in the normal location for a 12F device. Pin 1 is located top-left.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
