be80be
Well I got the thing to scroll the leds now I need to add a way to change my patten here a look and here the code
and the two macro to shif out the data
if somebody wants to play with it I'll post the circuit if not I'll not waste my time drawing it out. I used a 74hc164 for the rolls and 2 74hc595 for col. and 3 75492PE led drivers.
#include <p12f683.inc> ; Include pre-defined port/reg labels
errorlevel -302 ; suppress message 302 from list file
__CONFIG _FCMEN_ON & _IESO_OFF & _CP_OFF & _CPD_OFF & _BOD_OFF & _MCLRE_ON & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT
; for your specific device.
; Defines
cblock 0x20
TX
TX1 ; Define variable at address 0x20 of
CountSPI
CountSPI1
d1
d2
endc ; General Purpose Register (GPR) memory.
#define Data GPIO,0
#define Clock GPIO,1
#define Latch GPIO,2
#define Clock1 GPIO,4
#define Data1 GPIO,5
; PROGRAM CODE
org 0x0000 ; Processor Reset Vector (code starts here on reset)
goto Main ; On power-up, begin at label "Main:"
org 0x0004 ; Interrupt Vector (code jumps here on interrupt)
goto Main ; Applies to midrange parts!
include "hc595.inc"
include "hc164.inc"
; Place code to determine source of interrupt (check flags)
; and to handle interrupt accordingly here (your action)
; as your Interrupt Service Routine (ISR) code.
Main:
movlw 07h ;set GP<2:0> to
movfw CMCON0 ;digital I/O
banksel ANSEL;
clrf ANSEL;digtal I/O
banksel TRISIO
movlw b'001000' ;set inputs and outputs
movwf TRISIO ;moves it to TRIS ; Initialize any ports as inputs/outputs, etc. here
banksel GPIO
clrf GPIO
Loop:
Send
call col0
call Roll1
call col1
call Roll2
call col2
call Roll3
call col3
goto Send1
Send1
call col4
call Roll3
call col5
call Roll2
call col6
call Roll1
call col7
goto Send2
Send2
call col0
call Roll1
call col1
call Roll2
call col2
call Roll3
call col3
goto Send3
Send3
call col4
call Roll3
call col5
call Roll2
call col6
call Roll1
call col7
goto Send4
Send4
call col0
call Roll1
call col1
call Roll2
call col2
call Roll3
call col3
goto Send5
Send5
call col4
call Roll3
call col5
call Roll2
call col6
call Roll1
call col7
goto Send6
Send6
call col0
call Roll1
call col1
call Roll2
call col2
call Roll3
call col3
goto Send7
Send7
call col4
call Roll3
call col5
call Roll2
call col6
call Roll1
call col7 ; Place Application Code Here.
goto Send
col0
movlw 0x1 ;fill tx buffer
movwf TX
HC595 TX,CountSPI
call delay
return
col1
movlw 0x2 ;fill tx buffer
movwf TX
HC595 TX,CountSPI
call delay
return
col2
movlw 0x4 ;fill tx buffer
movwf TX
HC595 TX,CountSPI
call delay
return
col3
movlw 0x8 ;fill tx buffer
movwf TX
HC595 TX,CountSPI
call delay
return
col4
movlw 0x10 ;fill tx buffer
movwf TX
HC595 TX,CountSPI
call delay
return
col5
movlw 0x20 ;fill tx buffer
movwf TX
HC595 TX,CountSPI
call delay
return
col6
movlw 0x40 ;fill tx buffer
movwf TX
HC595 TX,CountSPI
call delay
return
col7
movlw 0x80 ;fill tx buffer
movwf TX
HC595 TX,CountSPI
call delay
return
Roll1:
movwf TX1
HC164 TX1,CountSPI1
return
Roll2:
movlw 0x1C ;fill tx buffer
movwf TX1
HC164 TX1,CountSPI1
return
Roll3:
movlw 0x3E ;fill tx buffer
movwf TX1
HC164 TX1,CountSPI1
return
Roll4:
movlw 0xff ;fill tx buffer
movwf TX1
HC164 TX1,CountSPI1
return
delay:
;29998 cycles
movlw 0x6F
movwf d1
movlw 0x18
movwf d2
Delay_0
decfsz d1, f
goto $+2
decfsz d2, f
goto Delay_0
;2 cycles
goto $+1
return
end ; Program code stops here
HC595 macro Var,Var1
Local Loop ;label
movlw .8 ;eight bits to send
movwf Var1
Loop
rlf Var,f ;rotate Var to the left
btfss STATUS,C ;carry = 1 ?
bcf Data ;if not set line to 0
btfsc STATUS,C ;is carry = 0 ?
bsf Data ;if not set, set data line to 1
bsf Clock ; generate 1 clock
nop
bcf Clock
decfsz Var1,f ;bits been sent ?
goto Loop ;if not repeat
bsf Latch
nop
bcf Latch
endm
HC164 macro Var0,Var2
Local Loop ;label
movwf Var2
Loop
rlf Var0,f ;rotate Var to the left
bcf Data1 ;if not set line to 0
bsf Data1 ;if not set, set data line to 1
bsf Clock1 ; generate 1 clock
nop
bcf Clock1
decfsz Var2,f ;bits been sent ?
endm
