dknguyen said:Accelerometers don't work very well as inclinometers when moving though (unless you know all your linear accelerations some other way so you can cancel them out). Then again...most inclinometers don't work well when you are moving...electrolytic, ball, etc.
dknguyen said:They are cheap and compact though! I like using the 3-axis versions. You add up all 3 vectors use use the angle of the final vector to to find the direction of gravity and then use that to figure out your incliniation ( no need to calibrate for G variations...that is, if you're paranoid about that kind of thing.)
