IDE chip
TKS
Hi all,
i'm searching for a new challenge and was searching for a ide communication chip to be placed in a network of pic cpu's or atmel one
does anybody has some experience whit IDE...
i have found a project on IDE but they use a 805X stucture i gess...
https://www.pjrc.com/tech/mp3/
- reading/writing to HDD's...
- reading from a CD-Rom drive //music or just data (Mp3..) (both via the IDE cable..)
TKS
I seem to remember there was a lot of discussion about this on the PICList a few years ago, from what I remember the main problem was the lack of memory with PIC's. I don't think anyone ever managed to get it sorted :cry:
IDE...
I found in previous topics this: **broken link removed**
but i don't know how to use it...
can you say me which chip is the IDE one...
TKS
Re: IDE...
It explains in the text, it uses the CPU to create the interface, it uses an external 32KB SRAM for the memory.
A very impressive design though!.
Re:
sow a cpu also can do this, for programming the interface whit a cpu you will need to untherstand the ide protocol right..?? in that way you will be able to put pins high/low to communicatie..??
(now i untherstand wy some lines also are used for the display..and wy he talks about switching in modes...//in fact he need more pins right..???)
i think is better to use a chip dedicated to that...offcourse the design will be expensiver and bigger (space needed) but i think i will be more stable and easyer for beginners....
will read the text..
still need a all in one cpu..for ide connexions..
TKS
IDE think i have somte thing.....
This file is part of the XTIDE project.
XTIDE is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
as published by the Free Software Foundation; either version
2, or (at your option) any later version.
XTIDE is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty
of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See
the GNU General Public License for more details.
You should have received a copy of the GNU General Public
License along with XTIDE; see the file COPYING. If not,
write to the Free Software Foundation, 675 Mass Ave,
Cambridge, MA 02139, USA.
XT BUS U1 | U2 U3 | IDE
| D0-D7|<---->|A B|<-+-->|D Q|<-+---->|D Q|<--+-->|D0-D7 |
| *IOR|----->|DIR | 2->|*OC | | 4->|*OC | | |
| | 1->|*G | 3->|C | | 5->|C | | |
| | |\ | +------------------>|D8-D15 |
| | VCC---/\/\/\/---| >|----------------------->|*DASP |
| | 151 OHM |/ | U4 | |
| | LED ------- | |
| | 6->|1D 1Q|------>|*CS3FX |
| | 7->|2D 2Q|------>|*CS1FX |
| A2|--------------------------------->|3D 3Q|------>|A2 |
| A0|--------------------------------->|4D 4Q|------>|A0 |
| A1|--------------------------------->|5D 5Q|------>|A1 |
| *IOR|--------------------------------->|6D 6Q|------>|*IOR |
| *IOW|--------------------------------->|7D 7Q|------>|*IOW |
| | U5:B +---------------->|8D 8Q|------>|*RESET |
| | |\ | GND->|*OC | | |
|RESDRV|--------| >O----+ VCC->|C | | |
| IRQ5|<-----------------------------------------------|INTRQ |
| | U6 ---------
| AEN|--------------->|*G | +-->1 U5:A U8:A
| A4-A9|--------------->|P0-P5 | | |\ ------
| | GND->|P6 | | +----| >O---| |
| | GND->|P7 | | | |/ | OR |-->6
| | GND->8DIPSW->|Q0-Q7 | +---------|-----------| |
| | | *P=Q|----+ | U8:B
| A3|----------------------------|---------+-----------| |
| | | | OR |-->7
| | | U7 ------
| | | ---------- U5:C
| *IOW|----------------------------|--->|A | |\
| *IOR|----------------------------|--->|B Y1|-----| >O------>5
| A3|----------------------------|--->|C | |/
| | | | Y2|--------------->2
| | U8:C | | Y5|--------------->4
| | ------ U5:E +--------|--->|G1 | U5:D
| A2|--->| | |\ | +--->|*G2A | |\
| | | OR |---| >O--+ +------->|*G2B Y6|-----| >O------>3
| A1|--->| | |/ | ---------- |/
| A0|------------------------+
IDE CONNECTOR ICs Used
1 *RESET 2 GND U1 74245
3 D7 4 D8 U2, U3, U4 74573
5 D6 6 D9 U5 7404
7 D5 8 D10 U6 74520
9 D4 10 D11 U7 74138
11 D3 12 D12 U8 7432
13 D2 14 D13
15 D1 16 D14
17 D0 18 D15 10K PULLDOWN: 3, 21, 27
19 GND 20 (keypin) 10K PULLUP: 28
21 DMARQ 22 GND NO CONNECTION: 20, 29, 32, 34
23 *IOW 24 GND
25 *IOR 26 GND
27 IORDY 28 CSEL
29 DMACK 30 GND
31 INTRQ 32 IOCS16
33 A1 34 PDIAG
35 A0 36 A2
37 *CS1FX 38 *CS3FX
39 *DASP 40 GND
do you unther stand this..??/
i a bit i think...
TKS
S-ATA instead of IDE
IDE uses 40 wires serial ata only a couple of them...
wouldn't it be easyer to use serial ata in a project instead of ide..??
or is this to simple..
TKS
SATA works in serial format but with extreme clocks (i *think* 500Mhz), And PATA works around 100 Mhz (I *think*). To interface a microcontroller to this would be insane, if not impossible.
