Hi. THere is a section in the International Rectifier Application Notes that talks about sizing boostrap capacitors for gate drivers. It says that the operation of the boostrapping circuitry can lead to overcharging of the capacitor which will damage the IC and to prevent this the capacitor must be (rule of thumb) at least 15x larger than the minimum size which is actually needed to sustain the gate drive.
DOes anyone know anything more about this overcharging? Because I am wanting to use a boostrap capacitor (rather than an isolated supply) with the Adum1234 isolated gate drivers from Analog Devices and the single capacitors large enough cost a bundle (ceramics, I am not using electrolytics for this).
Also, 4.7uF capacitors cost $0.67 each while 22uF capacitors cost $4.89 each. But I don't have enough space in the PCB to place a bunch of 4.7uF capacitors. Is it a bad idea to "stack" SMD capacitors onto each other?
https://www.electro-tech-online.com/custompdfs/2008/03/dt98-2.pdf
