mobile mini robot
darsin
Hi all.
I'm final year student. I'm actually taking a project which called mobile mini robot.
It needed wireless communication between PC and robots but i'll be doing 1 robot first instead of robots.
the question i would like to ask is:
1) what microcontroller is the best to achieve on robot? PIC16F877 is it possible?
2) can you all tell me which wireless communication is better and cheaper?
3) i would like to add up some sensors on it. so i decide to use IR sensors to sense the obstacle. can you all provide me some info on it?
thanks!!!
i am working on a similar project and using the PIC16F877A
for wireless communication, there is RS232 wireless chip, I havent tried it yet but i know a guy used it for a project and says its easy to use
for sensors and ideas check this website:
How to Build a Robot Tutorial - Society of Robots
and if you using the PIC16F877
this website is a good start:
https://www.mikroe.com/en/books/picbasicbook/06.htm
you can use proximity sensor to detect objects
now i am trying to find a speed sensor to put on my project,,
oh that's cool! RS232 chip can be used for wireless communication between PC and robot? if u got any information about that do please tell me...i'm really appreciate that you provide this useful link for me....
I'm more familiar on using C programming.
but thanks anyway...thank you very much...
Hi...bentech4u..can you tell me what is this IC for?
is it wireless comm btw pc and robot?
frnd please search MICRF 007 & 102's data sheet
this is wireless TXR & RXR (Coil less)
this is a simple 8 legged IC-you can get the ful circuit & PCB design in original data sheet
thanks
i will ask my friend about that and let you know soon
i think its better you switch to 18f series(probably 18f4550) as it has got usb interface and you can easily program it using c18 compiler:)
regards
my first bot
i used this PIC18F4550 before when i was doing my diploma project. But i don't think that USB is neccessary for me because i'm using wireless. furthermore usb interface's code is not that easy and need some time to understand the coding.
