brocken HDD
Thunderchild
A friend asked me to look at their computer as it said: operating system not found, meaning in realistic terms that something was wrong with the HDD
So I've taken the HDD out and tried it in an enclosure and low and behold its dead - stone dead not a flicker won't even spin up.
is it possible that its the controller circuit thats faulty ? can this be replace with an old one ?
Broken HD
is it possible that its the controller circuit that's faulty ? can this be replace with an old one ?
I have heard of people finding an IDENTICAL working HD and swapping out the controller board just long enough to salvage data from the dead drive. Of course there is no guarantee the platters themselves are still good. Depending on the "value" of the data it might be worth a try.
well they have their photos on them so obviously would like to have these back.
its an old Maxtor 541DX 5400 RPM 20 GB UATA100 hard drive any ideas where I can get another one ?
so how do I identify a brocken fuse ? from what I was told it went down from one day to the next rather than slowly playing up. I my limited experience with HDDs breaking down its not that rapid and the plates still spin even when the rest packs up
Almost certainly long obselete, you would have to find a second hand one somewhere.
Not surprised to hear it's a Maxtor, they are incredibly unreliable - almost all HDD's I've changed have been Maxtor.
Im the exact opposite - while Ive found better deals lately buying Seagate 7200.11 drives, all the Maxtor drives I had held up fine.
OP, here is a PCB board for your 541DX that you could swap with:
If you could upload a close-shot picture of your HDD circuit board (close to the PSU connector), maybe we could help you to find the possible blown fuse. This have to be a really clean picture though.
here is a pic, let me know if you need more area
Check those 2 1R00 resistors, then the ferrite bead (the gray thing next to INDEX label).
Would be nice too see some other PCB sections as well. underneath too.
I can't tell how hard/easy it is, it all depend of your own experience and patience ;)
If possible, divide the PCB in 4 section for the top, 4 for the bottom. I don't know how crazy it is... maybe we do this for nothing, but If we don't try we'll never know ;)
the 1 ohm resistors are measuring more like 21-22 ohms, I'm currently working on an image of the whole board (didn't you know you could do a panoramic image of a circuit board ;-) )
Good enough. I guess it would be good to see the other side of this PCB. Seems pretty easy to remove the controller board. Remove all screw, then gently remove the PCB. Look how the motor is connected to it.
I would probably suggest to check all those ferrite bead and all 0 ohm resistor/jumper, check voltage at VR200 output (should be 8Volt) and all other test point. But yeah... is there voltage everywhere if only connected to an ATX supply??? can't tell myself.
