PIC16f690, initialisation of ports, LEDS,reading from a pin
I want an LED connected to pin RAO to glow if pin RA1==0
when i run my code the LED keeps pulsing on and off regardless of what value RA1 equals to.
could someone plz help me. Thanks
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
void init(void)
	TRISB=0x00;
	TRISC=0xFC;
	ANSEL=0;        // Set inputs to digital
       TRISA=0x02;	//making pin RA1 input
void main(void)
    init();	// initialise I/O ports, LCD
    while(1)                        //  Loop forever
    if(RA1==0)          		//if receiver detects something then output is active low
      		{PORTA=0x01;}	//light up led connected to RA0 if detect object
    else
      		{PORTA=0x00;}	//dont light led if no detection
He is toggling the whole porta and hasn't set porta up right
What C are you using ?
im a "she" hehe. im using hi-tech c pic lite in mplab. Im a beginner. Plz assist me.
Try this:
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
void init(void)
	TRISB=0x00;
	TRISC=0xFC;
       TRISA=0x0A;	//making pin RA1 and RA3 input (RA3 is always an input)
void main(void)
      		{RA0=1;}	//light up led connected to RA0 if detect object
    else
      		{RA0=0;}	//dont light led if no detection
By using RA0 instead of PORTA you're just setting the one bit for your LED.
Also, what do you have connected to RA1? If it's a switch or button, you should use a pull-up resistor, or the built-in weak pullup on RA1, which you can enable by adding to your init() function:
  WPUA1 = 1;
  RABPU = 0;
This code works if you set the hardware up right.
#include <pic.h>
void init(void)
	TRISA=0x2;
	TRISB=0x00;
	TRISC=0x00;
void main(void)
    else
Here how i set it up
To me this looks better
#include <pic.h>
void init(void)
	TRISA=0x2;
	TRISB=0x00;
	TRISC=0x00;
void main(void)
    else
sorry didnt respond quicker, i was learning for a test which i wrote 2day. RA1 has an infrared receiver module(TSOP48) connected to it. The output is active low. I never connect a switch there. I tried your code Kpatz but the LED is still pulsing continuously. thanks Be80be and Kpatz for taking time to try and help me.
Hey fantabulous68 I thought you have connected an IR module on your input.Of course it will toggle when it receives IR pulses :)
If you are checking from a switch don't forget to put a pull up resister on the input pin like 4.7K.
My design is an infrared liquid level detector. Im in the beginning stages of my design. I want to get the led indicator working for now. The hardware for my proximity detection circuit is working. When an object is detected the receiver IC outputs a low which is fed INTO pin RA1. i want an LED connected to RA0 to glow when detection occurs. All the LCD functions work.
Im having some problems with my code. I suspect the problem lies in my init function and main program. tink my initialisation of portA is wrong and maybe the order in which i call ledindicator function.
1) The LEDindicator function doesnt work when i join it as a entire program with the LCD funtion. It only works separately. I need it to work together
Please assist me in getting the code working. Thanx
yeah thanks Gayan Soyza, i realised that when the microcontroller function generates 40KHz, the LED blinks on and off real fast HOWEVER, with the NEW code that im using below. The LED is permanently ON at all times. i only want the led to glow when an object is detected. eg if detect object then LED glows, if dont detect then led doesnt glow. i dont want the led permanently on.. What should i do? im generating a 40khz pulse at RA2 and that is an output from the microcontroller. The receiver module is connected to RA1. when it detects an object it outpus a low which is fed into the microcontroller. The LED is connected to RA0.
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
void FloatToStr(float , char[]);
void DelayMs(unsigned char);
void lcd_cmd(unsigned char);
void lcd_data(unsigned char);
void lcd_clear(void);
void lcd_puts(const char[]);
void lcd_goto_L1(void);
void lcd_goto_L2(void);
void lcd_cursor(unsigned char);
void lcd_init(void);
void enable_interrupt(void);
void interrupt isr(void);
void calc_distance(void);
void init(void);
void read_input_sw(void);
void home_screen(void);
void _40KhzTransmit(void);
void IndicatorLED(void);
#define LCD_RS RC0		//LCD RS pin
#define LCD_EN RC1		//LCD EN pin
#define LCD_STROBE()	LCD_EN = 1; asm("nop"); asm("nop"); LCD_EN = 0
char input_sw;
unsigned char i,j,k;
char temp[8];
///////////////////////CONVERT FLOAT TO STRING///////////////////
// This function was taken from the CAVR library. It was modified slightly
// to suit our design.
void FloatToStr(float n, char str[])
float scale;
unsigned char d,f;
f=0;i=0;
if (n<0.0) {n=-n; str[f]='-'; f++;};
n=n+0.005;
scale=1.0;
while (n>=scale) {scale=scale*10.0; ++i;};
if (i==0) {str[f]='0'; f++;}
else
while (i--)
      scale=floor(0.5+scale/10.0);
      d=(unsigned char) (n/scale);
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
for (j=0;j<=1;j++) //2 decimal points
      n=n*10.0;
      d=(unsigned char) n;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
///////////////////END CONVERT FLOAT TO STRING///////////////////
/////////////////////////////DELAY///////////////////////////////
void DelayMs(unsigned char cnt)
#if	XTAL_FREQ <= 2MHZ
	do {
		DelayUs(996);
	} while(--cnt);
#endif
#if    XTAL_FREQ > 2MHZ
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
void DelayS(unsigned char cnt)
	for (j=0; j<(cnt*10); j++)
		DelayMs(100);
///////////////////////////DELAY END/////////////////////////////
//////////////////////////////LCD SETUP//////////////////////////
/* send a command to the LCD */
void lcd_cmd(unsigned char c)
	DelayMs(20); //wait for LCD to be ready
	LCD_RS = 0;	 //write instruction
	PORTB = (c & 0xF0); //load upper nibble on LCD data lines
	LCD_STROBE(); //send instruction to LCD
	PORTB = ((c << 4) & 0xF0); //load upper nibble on LCD data lines
/* send data to the LCD */
void lcd_data(unsigned char c)
	PORTB = 0x00;
	LCD_RS = 1; //write data
    PORTB |= (c & 0xF0); //load upper nibble on LCD data lines
	PORTB &= 0x00; //load upper nibble on LCD data lines
	PORTB |= ( (c << 4) & 0xF0);
/*Clear the LCD*/
	lcd_cmd(0x01); //command to clear LCD
/*write a string of chars to the LCD*/
void lcd_puts(const char s[])
	j = -1;
	while(s[++j]!=('\0')) // send characters until null character reached
		lcd_data(s[j]);
/*go to beginning of line 1*/
	lcd_cmd(0b10000000); // command to go to line 1
/*go to beginning of line 2*/
	lcd_cmd(0b11000000); // command to go to line 2
/*move cursor "x" positions to the right*/
void lcd_cursor(unsigned char x)
	lcd_cmd(((x)&0x7F)|0x80);
/*initialise the LCD - put into 4 bit mode*/
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	DelayMs(20); //wait for LCD startup
	lcd_cmd(0x28);	// 4-bit mode
	lcd_cmd(0x08);	// display off
	lcd_cmd(0x01);	// clear display
	lcd_cmd(0x0C);	// disp. on, cursor off, cursor blink off
	lcd_cmd(0x06);	// entry mode
	lcd_cmd(0x80);  // initialise DDRAM address to zero
//////////////////////////LCD SETUP END//////////////////////////
void init(void)
	OSCCON|=0x60; //set fosc to 4Mhz
	TRISB=0x00;
	TRISC=0xFC;
	ANSEL=0;	//
	TRISA=0x02;	//
    //ANSELH=0x00;
	lcd_init(); //call LCD initialisation
	GIE=0; //disable global interrupt
	lcd_clear();
	lcd_goto_L1();
	lcd_puts("INFRARED LIQUID"); //home screen message (line 1)
	lcd_goto_L2();
	lcd_puts("LEVEL DETECTOR"); //home screen message (line 2)
	int t=0;
	int cnt=0;
	while(cnt<20)
		{	if (t==0)
				PORTA=PORTA^0x04;  //toggles RA2
				DelayUs(13);
				cnt++;
				t=1;
			else if (t==1)
				PORTA=PORTA^0x04;
				DelayUs(12);
				cnt++;
				t=0;
    if(RA1==0)          	//if receiver IC TSOP48 at pin RA1 detects something then output is active low
    else
void main(void)
	while (1)
	IndicatorLED();
	home_screen();
i got it to do what i wanted. It just had to swap the order of the two functions in my main program. YAY :). Im a happy girl now
im going to start working on my timer 1 code. i need the time interval between the reflected and detected infrared light in order to calculate distance from object. :)
Let's do some theoretical;
Assuming the 16f690 is running at 20Mhz, and then using timer1 is activated after 1 cycle, that would be 1/5Mhz which is 200ns
Light travels at 300 000km/s
Therefore the minimum distance would be 60 m total (there and back) if you assume the LED can turn on and off within 1 cycle which I don't think it can :)
Try a Sharp rangefinder instead
im not allowed to use a sharp range finder. I have to design an infrared liquid level detector for my design course.
