Old 26th December 2008, 10:09 PM   #1
Default DIY Dallas 1 Wire Slave discussion.
For a while I have been thinking it would be interesting to write the uC code for a Dallas 1 Wire slave.
Either it is an unpopular idea, or it has been discouraged by the Maxim Dallas people. About 2 weeks ago I found a vendor document stating that they have not allocated any device addresses/types for 3rd party use. About the same time I saw what was untested BASIC code.
3v0
BCHS/3v0's Tutorials
3v0 is offline
Old 26th December 2008, 10:10 PM   #2
There's tons of 1 wire code. Search for iButton.
Bill
Smart Kits build Smart People
Old 26th December 2008, 10:14 PM   #3
We have all written or used code to talk to slaves. I do not see code to create a slave.
3v0 is offline
Old 26th December 2008, 10:17 PM   #4
Ahh you want to emulate an ibutton. Nope I've not seen any code for that.
Bill
Old 26th December 2008, 10:23 PM   #5
Morning Bill. LOL
EDIT: I was looking for a bit of chat about the merits of creating a custom slave.
3v0 is offline
Old 26th December 2008, 10:26 PM   #6
I admit I've never thought of using the Maxim/Dallas 1-wire protocol.
I have however implemented a much higher speed Icom 1-wire (open-drain) CI-V protocol on a 12F683 based Ham radio accessory. The CI-V protocol uses standard serial data (8/1/N) at 5 volt TTL levels which necessarily limits the 1-wire bus length to relatively short distances. The packet protocol includes two header bytes ($FE, $FE), "To" and "From" address bytes, variable number of data bytes, and an $FD end-of-record byte.
Ekki DF4OR's CI-V Info' Pages
Regards, Mike
Mike, K8LH is offline
Old 26th December 2008, 10:34 PM   #7
I have been using 1 wire sensing (mostly temperature) for over two years and find them to be very durable. I have them outside, in the greenhouse and garage, and koi ponds.
In time I would like to create a monitoring, control, and security network. Speed is not important but not having to make repairs is.
There are some functions that the available 1 wire products do not address. A DIY slave based on a uC would fill the void.
3v0 is offline
Old 27th December 2008, 02:19 AM   #8
I have thought of doing this a few times. You could just make your slave look like a DS18x20 but return an invalid temperature (+127) when queried so you know it is your slave and you can then send it any custom commands you like. I thought of programming a 509 to act as a slave so I²C/SPI devices could be added to a OW bus. An obvious omission in OW devices is a humidity sensor.
<edit>Implementing the searchrom algorithm would be fun. I have managed to implement the searchrom and send RS232 on a 10f200! Fitting that into 256 words was a challenge.</edit>
Pommie is online now
Old 27th December 2008, 02:53 AM   #9
They have discontinued the DS2423 counter which was popular for building tip bucket type rain gauges.
I doubt one could put together a setup using parasite power but it is worth looking at. If not you will need a 3rd conductor or provide local power for the custom devices, maybe solar. Would be interesting.
3v0 is offline
Old 27th December 2008, 03:42 AM   #10
I think the parasitic power would be the easy bit. The protection diodes would conduct and so you would just need capacitors on the supply pins.
I might have a play with this in the new year.
Old 28th December 2008, 02:05 PM   #11
Here are 1-wire slave routines in asm:
Koders Code Search: 1wslave.asm - Assembler
"The only thing worse than getting an error message is not getting an error message." - Allen Downey
qratman is offline
Old 28th December 2008, 02:32 PM   #12
Thank you. That looks like a very comprehensive (and impressive) sub-system...
Old 28th December 2008, 02:38 PM   #13
I have never seen this search engine. Cool.
Now to find it in C
3v0 is offline
Old 28th December 2008, 03:10 PM   #14
That is very impressive code. I'm looking forward to studying it (not now though - 1AM here).
Old 7th January 2009, 10:15 PM   #15
I goggled 1wire slave and found three addresses.
First one has C code.
www.alres.pl/pub/emul_1W.zip
www.alres.pl/glowna/pomoce/emul.html
or in English Translated version
Second one, only hex code home.hetnet.nl/~thomas_7/1Wire/1-WireIOPort.html
Last one, no source code www.louisswart.co.za/1-Wire_Overview.html
Regards,
Mustafa
Mustafa is offline
dallas, discussion, diy, slave, wire
where is the discussion about how electionrejection Alternative Energy 1 16th March 2008 12:26 AM
H Bridge... Design, Discussion. Ayne Micro Controllers 5 18th February 2007 11:41 PM
Dallas DS18B20 Characteristics? Mike, K8LH Micro Controllers 8 16th September 2006 01:22 AM
Dallas 80C323 crowinu Micro Controllers 3 13th April 2006 06:40 PM
Very basic question for discussion Ravi General Electronics Chat 3 29th August 2003 03:20 AM
