Old 4th April 2008, 01:13 PM   (permalink)
Sure post the code, the NOPs sound like a RWM problem.
Bill
Smart Kits build Smart People
Old 4th April 2008, 04:28 PM   (permalink)
Hi Bill,
actually the problem with NOPs is described in the datasheet. As you can see I have modified your source code, this is the last version and the one that actually works - if you have PIC16F887 you can try yourself.
I am designing a frequency counter and I'd like to use PIC16F886 and 16x2 LCD display so Unicorn with PIC16F887 seems as a good starting point to me.
Petr
;UNICORN LCD test, jumper on J1VEB, 8 bit mode with full handshaking
		list p=16F887
		include <p16F887.inc>
		__CONFIG	_CONFIG1, _HS_OSC & _WDT_OFF & _LVP_OFF & _DEBUG_ON
;		CONFIG FOSC = INTOSC_HS, WDT = OFF, LVP = OFF, PBADEN = OFF
        errorlevel      -302,-305
#define LCD_E 	PORTE,2
#define LCD_RS 	PORTE,0
#define LCD_RW 	PORTE,1
#define LCD_BL 	PORTB,3
#define LED_N	PORTC,1
                cblock  0x20
		msdelay:2
		delay
		temp
		endc
		org 	0
		banksel	ANSEL			; select BANK 3
		clrf	ANSEL
		clrf	ANSELH
		movlw	0x80			; prepare to read FLASH
		movwf	EECON1
		bcf		STATUS,RP0		; select BANK 3 -> BANK 2
		movlw	HIGH LCD_CC
		movwf	EEADRH
		banksel	TRISB			; select BANK 1
		bcf 	TRISB,3 		; LCD backlight control
		clrf 	TRISD 			; LCD data output
		clrf 	TRISE 			; LCD control outputs
		bcf		TRISC,1
		clrf	PSTRCON
		bcf		STATUS,RP0		; select BANK 0
		clrf 	PORTE 			; LCD E, RS, RW
		bsf		LED_N
; LCD soft reset (ignores/enables busy flag polling)
		movlw 	.4 				; repeat sending 0x38 to reset LCD
		movwf 	temp 			; loop counter
init3:	       movlw 	.50 			; delay > 50 ms
		movwf 	delay 			; enter with delay in ms via W
dec01:	      call	mswait		; wait 1 ms
		decfsz 	delay 			; decrement delay and skip when zero
		goto 	dec01 			; branch backwards one instruction
		bsf 	LCD_E 			; LCD enable bit high
		nop
		nop
		nop
		nop
		movlw 	0x38 			; send 0x38 four times
		movwf 	PORTD 			; LCD = 0x38 (8 bit mode x 2 line)
		nop
		nop
		nop
		nop
		nop
		nop
		bcf 	LCD_E 			; latches on High to Low transition
		decfsz 	temp
		goto 	init3 			; repeat 3 times
		bsf 	LCD_BL 			; turn on backlight
		call	mswait
; load special charaters into LCD RAM using LCD busy flag
		movlw 	b'01000000' 	; set LCD CG address to 00
		call 	LCD_Ins 		; relative call
		clrf 	temp
		movlw 	LOW LCD_CC 		; pointer to custom character table
		bsf		STATUS,RP1		; BANK0 -> BANK2
		movwf 	EEADR
nextcc:	      call	rdflash
		call 	LCD_Chr 		; send the character into LCD RAM
		incf 	temp
		btfss 	temp, 6 		; 64 bytes total
		goto 	nextcc
; clear & enable LCD DRAM, no visible cursor
		movlw 	0x0C 			; display on, cursor off
		call 	LCD_Ins
; display top 16 characters
		movlw 	0x01 			; clear display, home cursor
		call 	LCD_Ins
		movlw 	.16
		movwf 	temp
		movlw 	LOW Text_ 		; low byte pointer
		movwf 	EEADR
top: 	        call	rdflash
		call 	LCD_Chr
		decfsz 	temp
		goto	top
; display bottom 16 characters
		movlw 	0xC0 			; set cursor to second line
		call 	LCD_Ins 		; LCD instruction mode
		movlw 	.16
		movwf 	temp
bottom:	      call	rdflash
		call 	LCD_Chr 		; LCD character mode
		decfsz 	temp
		goto 	bottom
		nop
		nop
		bcf		LED_N
		goto 	$ 					; endless loop done
; wait approx 1 ms
mswait	        movlw	4
		movwf	msdelay+1
msd		movlw	.250
		movwf	msdelay
msdl	        nop
		decfsz	msdelay
		goto	msdl
		decfsz	msdelay+1
		goto	msd
		return
; read one byte from program flash, increment EEADDR
rdflash:        bsf	      STATUS,RP0		; BANK3
		bsf		STATUS,RP1		; BANK3
		bsf		EECON1,EEPGD
		bsf		EECON1,RD		; 2 NOPs MUST (!) follow after reading program FLASH
		nop
		nop
		bcf		STATUS,RP0		; BANK3 -> BANK2
		incf	    EEADR
		movf	  EEDAT,W
		bcf		STATUS,RP1		; BANK2 -> BANK0
		return
; LCD entry routines watches busy flag
LCD_Chr       bsf 	LCD_RS 			; enable character mode
LCD_Ins        bsf		STATUS,RP0	; -> BANK1
		clrf 	TRISD 			; make PORTD an output
		bcf		STATUS,RP0  ; -> BANK0
		movwf 	PORTD 			; put data on LCD port
		bcf 	LCD_RW
		nop
		bsf 	LCD_E
		nop
		nop
		nop
		nop
		bcf 	LCD_E 			; latch byte to LCD
		nop
		bcf 	LCD_RS
		movlw	0xff
		movwf 	TRISD 			; make LCD port input
		bsf 	LCD_RW 			; enter read mode
		bsf 	LCD_E 			; enable LCD
BusyF	btfsc 	PORTD,7 		; wait for bit 7 to be pulled low
		goto 	BusyF
		bcf		LCD_E
		bcf 	LCD_RW 			; return to instruction mode
		return
; text to display (Table with two bytes per word)
		org 	0x0400
Text_	       dt 	      "blueroom      ",.0,.1
		dt 		"electronics   ",.2,.3
; *** 2x2 blueroomelectronics logo (house)
LCD_CC	    dt 		.128,.128,.129,.131,.135,.143,.159,.159
		dt 		.128,.128,.128,.144,.152,.156,.158,.130
		dt 		.159,.159,.159,.145,.145,.145,.159,.128
		dt 		.130,.130,.158,.130,.130,.130,.158,.128
		END
petrv is offline
Old 8th April 2008, 08:20 AM   (permalink)
Thumbs up Unicorn & LCD - Test/Demo Program
I have created a module or program errrrrrrrrrr maybe i'll just call it a file over the last couple of days since receiving my Unicorn & 2 line LCD display.
I wrote this with the MPLAB C18 C compiler. Thanks to a lot of the conversation & examples i found here + other places i was able to get enough of the callable routines put together that I can now get on with working on my little application. I used the Junebug between MPLAB and the UNICORN.
There's a lot of documentation in the "C" source file - almost everything i found & learned i put into either the comments or in the #define MACROS.
20 years ago when i made a living as a "C" programmer we weren't allowed to put literals in our code - if it's a good habit - then good habits are hard to break!
I've got a compile conditional near the top of the file that can be changed and the entire thing recompiled for either 4 bit or 8 bit data access.
As a final test before posting it i tried transferring each of the hex files to the Unicorn via PicKit2 instead of MPLAB - and noticed that my delay's during the 'demo' are quite long. Maybe someone knows of a way i can put logic in my code to know whether or not i'm running under MPLAB?
The .zip file contains the C source file plus two .hex files - one was compiled for 4 bit and the other for 8 bit.
I spent most of my time getting the 'soft character' loading thing to work - DOH - i was trying to send the bitmaps via the control port instead of the data port!
This is my first PIC program - so you may have to cut me some slack! If you see anything in my source code that needs to be tweaked please let me know - i'm learning!
I have a couple of questions that i can't find answers to - if there are any of you that might be kind enough to help me with:
1) On the UNICORN I can read switches 1 & 2 reliably - switch 3 is flaky and switch 4 i can't read at all. I removed the CPU and checked the switch with an ohm meter - it's not the switch. I noticed there are not any pullups on Switch 3 or 4 which puzzles me - can anyone shed any light on this? I would like to use all four switches if possible.
2) I need to monitor some 12v (DC) signals - is it okay to connect the UNICORN inputs directly to 12v DC signals or is there some more 'electronic glue' required? (I'm a quart or two low in the EE department :P).
3) Anyone have any pointers on switch de-bouncing? What works, what doesn't?
4) Anyone have any good examples of working interrupt code in "C" that's triggered from switch closure AND that's triggered from one of the input pins changing state?
It's 3:15am - i think i better go to bed! Amazing how time flies when you are having fun!
Thanks & thanks for all the help so far!
David / W9GF
w9gf@arrl.net
David / W9GF is offline
Old 10th April 2008, 05:50 PM   (permalink)
Ahh is this the thread? I'll look at it, you have to enable weak pullups on port B for the pushbuttons to function. I'll look at the code shortly.
Bill
Old 10th April 2008, 09:13 PM   (permalink)
ha - okay - as the "Father of the Unicorn" - it may bring a tear to your eye!
Old 11th April 2008, 08:08 PM   (permalink)
Yes, thank you Bill for the Unicorn - it really helps me with my design of the frequency counter with LCD display. I have now finally a first skeleton of the software for the PIC that can actually work, I just need to run a fest tests ...
Petr
petrv is offline
HD44780 lcd help jay543_uk Micro Controllers 12 8th November 2007 03:26 PM
PIC16F628A LCD problems. HerbertMunch Micro Controllers 17 2nd October 2007 09:19 AM
LCD Troubles Kyle-s4h Micro Controllers 13 11th September 2007 12:30 PM
