Old 10th February 2009, 06:33 AM   #1
Default Battery for DS1307
DS1307 is a real time clock. I use it in my project. The battery for backing up during power failure is specified as 2 to 3.5 V. I used CR2025 3V lithium battery which is working fine.
Can I use 3.6V 60mAH Ni Cd battery instead as in the circuit with a zener ? What is the resistance value recommended?
premkumar9 is offline
Old 10th February 2009, 08:11 AM   #2
You could just connect a low voltage diode in series with the battery positive terminal.
A BAT85 or schottky low voltage diode should be OK.
Also I would connect a 100nF cap from the DS1307 battery pin to 0V.
ericgibbs is offline
Old 10th February 2009, 09:57 AM   #3
Like this?(ref attachment). Why do you suggest a 100nF capacitor ?
Old 10th February 2009, 10:11 AM   #4
Like this.
Old 10th February 2009, 10:17 AM   #5
Like this.
Can you just show the charging of this battery from Vcc (5V) also?
Old 10th February 2009, 10:27 AM   #6
The charge circuit is additional to the simple voltage dropper I posted.
Are you asking for a charger circuit.?
Old 10th February 2009, 10:35 AM   #7
Here, earlier I used a 3V (non rechargeable) battery. Now i am thinking of using a rechargeable battery marked as 3.6V. I want the charging from 5V supply of the IC. But the IC data sheet says the recommended battery voltage as 2 to 3.5V.
So I want to
1. Limit the voltage.
2.Charge it from 5V
Earlier I connected the 3V battery directly to the IC pin with out any extra cap or R .
Old 10th February 2009, 10:50 AM   #8
So I want to
2.Charge it from 5V
You are confusing two different points.
1..If you use a 3.6Vbty you need to drop the voltage by using the simple diode dropper in my post. This will meet the Vbty 2V to 3.5V requirement stated in the DS1307 data.
2.. The battery 3.6V NiCd charger is a different/additional circuit.
Old 10th February 2009, 11:14 AM   #9
There is a communication gap. In my OP i asked for resistance value to charge the bat from 5V (pls refer fig) , not for dropping the voltage.
Both the above (charging also) are my requirements.
Old 10th February 2009, 11:55 AM   #10
No problem.
Have a look at this circuit, keep the charge current to C/0.05 for simple float charge.
BTW: Looking at your OP, there is no reference to Charging or a 5V supply.
Old 10th February 2009, 02:45 PM   #11
No problem.
What is C?
I showed a resistance connected to Vcc(5V). Then my doubt was about the value of R(indicated charging current)
Old 10th February 2009, 03:09 PM   #12
What is C?
C for the battery you have [60mAH] is 60mA.
So C/0.05 = 0.06/0.05 = 1.2mA.
Old 19th July 2009, 07:48 AM   #13
Hi eric in your last schematic how did you calculate charging rate C/0.05 ?? The zenner votage is below the battery voltage V(z)3.0 < V(b)3.6V !!!!
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 19th July 2009, 08:38 AM   #14
Yes, I have the same question. The posted circuit is a constant-voltage charging circuit; not a constant-current method required by Nicads.
Nicads are probably the worst battery technology to use to back-up a real time clock. The useful life of the Nicad even under constant-current trickle charge will be less than the shelf life of the Cr2025 it replaces.
A better approach is to diode isolate the Cr2025 so that while the 5V is available, the operating current for the RTC comes from the 5V, and the battery supplies current to the RTC only in the absence of the 5V.
If you insist on using the Nicad, just calculate a resistor that will limit the charging current into the Nicad to less than the 0.05C rate. Under long term charging, the Nicad's terminal voltage will likely climb higher than the stated 3.6V, say 3.8V, so if the capacity (C) of the Nicad is 0.06Ah, the 0.05C rate would be 3mA, so R=(5-3.8)/0.003 = 400Ω
Mike ML.
MikeMl is offline
Old 19th July 2009, 09:17 AM   #15
hi Gayan,
Its a typo it should read 3v9, there isnt a 3v0 zener to my knowledge,?
The circuit shown is taken from the OKI, RTC clock applications book.
I used it for a number of years with OKI ic's and NiCd without any problems.
IMO, ideally is requires a lowish value resistor in series with the battery.
battery, ds1307
Swordfish DS1307 Example gramo Micro Controllers 5 27th April 2009 11:51 AM
DS1307 help amsung2 Micro Controllers 4 9th August 2008 01:02 PM
DS1307 with PIC16F877A neelam29 Micro Controllers 10 1st June 2007 01:24 PM
ds1307 with 89c51 baftab Micro Controllers 20 28th May 2007 10:27 AM
PIC and DS1307 huanyong Micro Controllers 1 6th November 2003 10:25 AM
