| I have got a white/blue LED that draws 100mA, how long would a plain, normal, standard 9V battery be able to supply enough current for the LED to light up brightly? And btw, what is the voltage drop over a normal led? Is the drop the same for the type of LED I've got hold of here? Cheers! Lac. | |
Since you said plain and normal, I assume it is alkaline type. Expect between 400 and 600 mAh. A good quality panasonic industrial type shows 570 mAh.. low end type probably more like 400. You should expect at least 4 hours out of your brightly lit LED. Typical forward drops for normal LED (for which a 100mA device is not normal) I am talking a T1 type or SMT type that runs up to around 20mA. Green is about 1.9V Blue (maybe white also - not sure) more like 2.5 - 3.5V Reds, ambers and similar are less than 1.9V I believe These are very rough numbers so consult the datasheet to be sure.. | ||
__________________ OLLY_K | ||
| Hi! If a 9V is approximatly 600mAh, can you tell me what for a AA? and for a AAA ? Also, is the difference big between a alkaline 9V and a carbon 9V ? Thanks in advance, | |
| AA's are 2700mAh. AAA's are 1175mAh (assuming Alkaline) An alternative for your White LED's drive, try 3x1.2V Nicads/NiMh, this gives 3.6V. which is ideal for white leds Even more sneaky, use One Nicad with one IC. ie: MAX1678. This gives a fixed 3.3V o/p @45mA (one Cell) or, 3.3V @90mA (2 cells) Steve | |
Notice that two Duracell AA's last about 8-9 hours at 200mA. | ||
| Hi! Your link doesn't work... | |
Try http://www.lpilsley.co.uk/viewbatt.htm and see if that works for you!. | ||
| Hi! Now it's ok. I suppose that the Panasonic High Power is a carbon one? | |
| Yes, they are! | |
| Yes, they are! | |
| Yeah, It's really useless. No cash to save their. | |
| those "high power" batteries sicken me!!, it's these kinds of batteries that are falsely marked. I wonder how the metal hydride types would match up???
__________________ www.winpicprog.co.uk - Great PIC language tutorials. | |
