Old 3rd March 2008, 12:17 PM   (permalink)
Default RF Tx,Rx Module ASK
Hi, im trying to use an RF Tx,Rx Module which uses ASK modulation at 433Mhz carrier .. how do i test its output ? i put a simple LED and tried to transmit some bits by a wire and it does reciever but there's some noise i feel it in the output led why is that ? i dont have a scope nor a function generator to test that really .. also i send 5V ampiltude why at the reciever the amplitude is 3V or less ? also can i send a byte without any noise or error , im really scared of that cuz i dont trust wireless or anything , dont know why ... and how to avoid noisy bytes or signals ? can i also send a byte and recieve it using this module like from serial PC to tx - Rx -> Pc ?
Thanks Alot in advance !
ahmedragia21 is offline   Reply With Quote
Old 3rd March 2008, 12:44 PM   (permalink)
Do you have a scanner? Tune it to the frequency, send something while recording the scanner output and view it on something like Audacity - assuming the material you transmitt is <20khz.
The noise may be due to poor shielding. I don't quite understand how you 'feel it in the output led'...
Could we have a schematic please?
Yes you can use the PC to send serial information - you can use Hyperterminal, comes free with Windows.
What is a joule per second?
erosennin is offline   Reply With Quote
Old 3rd March 2008, 12:48 PM   (permalink)
The led just emitts random light , like dancing , not quite steady , sorry am non-native ..
its the usual RF module 433MHz
http://www.sparkfun.com/commerce/pro...oducts_id=715]
no i mean , Send serial data from pc using that RF Module without any additional things ?
Old 3rd March 2008, 12:50 PM   (permalink)
Old 3rd March 2008, 12:52 PM   (permalink)
Check my PIC tutorials, which show one way to use them - bear in mind such modules are AC coupled, not DC.
Old 4th March 2008, 06:15 PM   (permalink)
so the soultion is to invert the uart signal ?
Old 5th March 2008, 10:22 AM   (permalink)
It's a very crude solution, the better way is to use Manchester coding.
Old 6th March 2008, 08:03 AM   (permalink)
Hi again , i want to know a simple experiment to test that module ... send a byte from the micro and recieve it at another micro ...
Old 6th March 2008, 06:25 PM   (permalink)
I've used this module this past week and found that if the transmitter and receiver are too close together (within about 6 feet of each other) the transmitter "overpowers" the receiver and you get a whole bunch of garbage on the receiving end. Also, attaching a small helical antenna to both the transmitter and receiver got rid of a lod of errors and garbage I was seeing, here's a link where I was talking about my results:
http://forum.sparkfun.com/viewtopic.php?t=9883
I was using a PIC uC to send a "Test" string ever 0.5s and receiving them on a PC with hyperterminal hooked to the receiver via a MAX232 IC.
Norlin is offline   Reply With Quote
RF module interface with PIC dilton13 General Electronics Chat 11 18th January 2008 05:37 PM
RF bit bot FirefighterBlu3 Electronic Projects Design/Ideas/Reviews 11 26th December 2007 09:26 PM
Chip talk dreamproject Electronic Projects Design/Ideas/Reviews 8 2nd April 2005 07:24 PM
Motor control interface dreamproject Micro Controllers 0 31st March 2005 03:48 AM
Safety interlock module wilfredmike Electronic Projects Design/Ideas/Reviews 6 2nd November 2003 08:41 PM
