Chemelec has been using a similar process for a long while. http://www3.telus.net/chemelec/Proje...ng/Etching.htm
Today I grabbed a un-etched PCB with a P&P (Press & Peel) circuit on it.
Then I rounded up a unregulated DC power supply, 10v-19v, 3.0 amp max.
After soldering a wire to the PCB and connecting it to the minus and the plus went to a small copper plate that I submerged in a plastic tray with enough water to cover. Made sure that the two didn't have a change to touch.
Than I added a little vinegar and a very small amount of table salt, don't ask me how much! Shortly thereafter bubbles started to form at the copper anode.
This was set up next to the kitchen sink, without my wife's permission!
Then I sat down to watch football, it was after all Sunday. During the advertising I went to check on my little experiment. No smell at all and couple of hours later about 95% of the PCB copper had migrated to the anode!
I should be able to etch the remaining copper with a standard etching solution in a matter of a few minutes at the most.
The advantage of all this is that you have much less exposure to noxious smells and of cause much less hazard's material to dispose of.
Yes, his is similar but he uses Old Sulphuric Battery Acid (diluted) but I use Vinegar and Salt. Quite a difference in chemistry, I would think but then I am no chemist.Originally Posted by 3v0
And I can pick up the PCB, for inspection with my bare fingers, no rubber gloves needed.
The reason for the experiment was to determine if I could cut down on the amount of hazardous chemicals used.
What you are dong is great, just wanted to give Chemlec his due... I am interested in giving it a try. Please post more details when you have them. These days it is not uncommon for to make a half dozen or more of the same boards for my students/kids. This sort of thing could cut down on the chemical cost.
http://en.wikipedia.org/wiki/Electro_chemical_machining
It has limited usefulness in PCB etching, chemical methods aren't really that bad and the electro-chemical method stops working if electrical contact is broken and can etch underneath the masking media more readily than a pure chemical reaction can so it becomes impractical for fine traces. If appropriate agitation is used in a chemical bath the copper removal rate on a PCB is almost completely uniform, the electrochemical method depends highly on the cathode to anode surface area ratio and distance of the applied electric fields. Current density variations occur from these difference and from the variations in the copper thickness and how that thickness effects the current density over time as the board etches at different points. I think it's most common industrial usage is as a final polish and surface finishing process on complex geometries, like turbine blades made out of exotic metals, because the pieces are relatively large so their electrical coupling is very strong, something as thin as the copper trace on a PCB is tenuous at best.. The surface area and current density calculations are so far past nightmarish that it would be applicable at best as an art, one however which I would respect, but art non-the-less. As you scale up the process chemical etching a board becomes more viable not less, otherwise this kind of thing would be used for mass production of PC boards, and it's not.
could mum, but I be a cat and no cat anywhere ever gave anyone a
straight answer, har har."
Given that etchants are not expensive it will not save a lot of money. But this is just the sort of thing that I like to play with. None of the practical concerns carry much weight because it is interesting. I think there is a place for that here. If not there should be.It has limited usefulness in PCB etching, chemical methods aren't really that bad...
Rather a misleading title? - 'no acid' - you then proceed to add acetic acid to the mixOriginally Posted by Rolf
Do that outside. Those bubbles are hydrogen.
C:\WHUT ?
Beware the asterisk *
I am not sure what you mean by quite a difference in chemistry. The advantage of using sulfuric acid in electrolysis versus NaCl as your primary electrolyte is there is no chance to produce chlorine gas.Originally Posted by Rolf
Although an explosion is probably unlikely if the process is well ventilated, hydrogen and chlorine form a classic, photochemically calatyzed, explosive mixture. John
Edit: Of course, chlorine by itself is a poisonous gas and has been used in warfare for that purpose.
If you want to go caveman, a basic graphite electrode can shape titanium in something as simple as salt water. Sulfuric acid is used yes, but only because it's a more efficient electrolyte. Proper venting for byproduct gases is a no-brainer, especially in a water based solution, electrolyte construction is 100% based on application to reduce byproducts and hence increase efficiency.
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| Lead Acid battery charger | manojp01 | Electronic Projects Design/Ideas/Reviews | 7 | 23rd June 2011, 09:07 AM |
| Cheap and good PCB etching solution..... | Rolf | Electronic Projects | 96 | 21st December 2009, 03:34 AM |
| DS2438 with 12V lead acid battery | monkeytennis | General Electronics Chat | 2 | 29th August 2006, 12:45 PM |
| how can etching be faster w/ feric chloride besides heat? | spyghost | Electronic Projects Design/Ideas/Reviews | 10 | 20th April 2004, 03:47 PM |
| Where to buy PCB etching components? | mattg2k4 | General Electronics Chat | 4 | 9th May 2003, 02:00 AM |
