Does anyone have a tried and tested technique for surface mounting DIP/DIL packaged IC's?
I was gonna bend the pins out or under and give it a try. I might even bend then over and mount the chip upside down for one particular circuit where the pinout would be much better 'mirror image'. I know it sounds daft, but I have my reasons. Anyone had any experience of this madness? Thanks in advance. -Dalmation. |
You can crop the pins/legs to shorten them if space is tight. Never used the method for upside/down mounting. CAUTION: the legs will break off, if repeatedly bent to and fro.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
IC socket: Through hole to SMT.
I'll experiment tonight (with the cheapest IC's I can find).
I'll also try converting some of my sockets into SMD. The upside down thing might be a bit ambitious, but I'm gonna try it anyway. I'll post pictures if I get good results. -DAlmation. |
I've bent the legs under the DIP package with success. You need to trim the leads back a bit so they don't touch any traces running under the IC.
It worked good for me. |
I had a wee go there.
Bent the bottom half of the legs outwards (90 degrees), then trimmed them back with snips (using a credit card as a spacer to leave a 1mm 'foot'. Looks just like a SOIC chip now. It makes the chip footprint quite wide, so I'll try bending under the chip as well. -Dalmation. |
| Surface mountable Capacitors/Resistors | BOBKA | General Electronics Chat | 15 | 13th May 2007 07:12 PM |
| How to deal with Surface Mounting components | aljamri | Electronic Projects Design/Ideas/Reviews | 17 | 24th February 2007 11:13 AM |
| surface mount soldering techniques | Richard Principal | General Electronics Chat | 5 | 12th November 2006 04:43 AM |
| surface mounting techniques | windozeuser | General Electronics Chat | 8 | 30th March 2006 02:08 AM |
| 16F84A surface mount | Johnson777717 | Micro Controllers | 4 | 28th June 2004 05:25 AM |
