I want to understand how audio amplifiers with discrete components work...
I found the following Headphone amp schematic which is the most simple i could get and i hope that someone can step by step explain it to me! |
That's a tiny class A amplifier, so not really a good subject to try and learn from.
But essentially the first transistor is a boot-strapped common emitter amplifier, and the second is a normal common emitter amplifier. The third transistor (at the top) is a constant current load for the output transistor. Can't say I think much of it, no negative feedback at all. |
the only thing i can understand on that design is the final stage transistors and the input/output capacitors!
i don't know what "a boot-strapped" means not " constant current load for the output transistor" do you think i should try to find another schematic of lets say AB class amplifier and upload it here so somebody can help me? |
It is a horrible amplifier.
Because it doesn't have DC negative feedback then the operating points of its first and third transistors could be with them cutoff or saturated or anywhere in between. Because it doesn't have AC negative feedback then its gain could be almost anything and its distortion will be high.
Uncle $crooge |
Here is a simple (too simple) class AB audio amp.
It has DC and AC negative feedback through the 390k resistor from the output to the input.
Uncle $crooge |
oh WOW!!! Audioguru you made me excited!!!
this schematic is really simple and i think i can understand it all of it without your help, so here i start! 0,47uF is a coupling capacitor for cutting any DC and for not letting any resistive loads interfere with the bias of the Q3 transistors. 27K is a the resistor to bias Q3 390K is the negative feedback resistor Q3 is the pre amplfication stage (voltage amplification) the diodes i don't know exactly what they are doing there The R2 regulates the emitter/collector voltage Q4/Q5 is the final stage... two transistors in push/pull which each one of them handle half period negative or positive. 470uF is an output capacitor to remove DC offset...(but probably destroys the frequency responce?) guys is that simple to understand an amplifier with descrete components?! I want to know some more classes other than AB... btw the schematic i uploaded it's more difficult for me, i don't understand it.... so how am i understand more difficult schematics? thank Audioguru!!! you're great!!! (i also thank the other guys too...) |
(permalink) | ||||||||
The 2.2k resistor does a poor job biasing Q4 because as the signal voltage rises at its base then its current is reduced. This "bootstrapped" modification allows constant current in the biasing resistor for Q4 (the voltage where the two 1k resistors join actually swings above the power supply voltage because the voltage across the 47uF capacitor remains constant). Then the output power is much higher and the distortion is much less.
Uncle $crooge |
(permalink) | |||||
right? Quote:
I liked very much this simple discrete amplifier... and i think i'll build it... can i learn specifications? output power/freq response/SNR? i know that my question is funny but i'm very excited... about the second schematic with the bootstrap thing... i'm still looking at it! Last edited by whiz115; 2nd October 2007 at 01:04 AM. |
just now i've made a speculation for the probably silly questions i'm doing at the end...
The 2N3904 is a very small transistor so it can't handle much current... and also too much voltage probably will make it too noise! so i guess it outputs much less than 0.5W, now about the others i guess i can't figure out easily. |
It uses the wrong transistors to drive an 8 ohm speaker. The 2N3904 and 2N3906 have a max current of 200mA which is a peak voltage of only 1.6V across the 8 ohm speaker. Then its max allowed output power is only 160mW. The BC337 can replace the 2N3904 and the BC327 can replace the 2N3906. They have a max current of 800mA. If they don't melt then the amp will produce the max power available from only a 9V supply which is about 1W when it is bootstrapped. Quote:
The noise is so low that you won't hear it. Quote:
Uncle $crooge |
Here are a few links with circuit explanation and construction projects on the subject matter -- they were easy to find with my browser:
http://headwize.com/projects/opamp_prj.htm http://www.zen22142.zen.co.uk/Circui.../headphone.htm http://sound.westhost.com/project24.htm http://www.tcaas.btinternet.co.uk/jlhphones.htm http://www.minidisc.org/headbanger.html
Don't make me reach through this monitor to slap you a good one! |
There is a headphones amplifier on the internet that uses opamps with only 0.00008% distortion. Nobody can hear distortion so low.
It wasn't good enough for the designer so he added a DC load to the opamp so its output operated in class-A to reduce the crossover distortion. HA!
Uncle $crooge |
Thanks HiTech...
Audioguru ok i have better understanding of the first schematic... and i also understand why you have these 2 diodes... now about the second schematic... the bootstrap if i understood it correctly takes signal from the output and sends it to the base of the transistors? i think i'm going to build this amplifier so i can see it working and understand it better... tell me what modifications to do without loosing the simplicity of the design! and without getting far from what i'm trying to understand with this design!! do you think something like a BD139/140 can make a better work? i want to make it on a breadboard so i can work up to 12V/1A Last edited by whiz115; 2nd October 2007 at 11:17 PM. |
| power electronics circuit analysis | ptewright | Electronic Projects Design/Ideas/Reviews | 2 | 25th November 2006 08:16 AM |
| Need help about a 7805 regulator circuit ! | Zarkabul | Electronic Projects Design/Ideas/Reviews | 26 | 13th June 2005 06:07 PM |
| Circuit auto OFF feature after no events design | Uman | Electronic Projects Design/Ideas/Reviews | 2 | 3rd May 2004 05:34 AM |
| HELP! a digital signal to close a circuit | fireismyflag | Electronic Projects Design/Ideas/Reviews | 2 | 22nd March 2004 10:45 PM |
| Circuit functioning very strange. Why? | Cyclone | Electronic Projects Design/Ideas/Reviews | 12 | 4th November 2003 12:30 AM |
