Digital Clock
Hello all,
I have to produce a functional digital clock using 7 segment displays. Can someone explain how a digital clock works and also point me in the right direction.
All i have right now is a 74283 connected to a 4511 to display it on a 7 segment display.
I really dont understand how to make this work. Ive been looking at a bunch of schematics and im just getting even more confused.
Thanks,
Tiago
Are you any good with microprocessors? This is an ideal project for a PIC microcontroller. If you are going to progress your electronics career, I strongly suggest you have a play with them - they will really make your expertese much better. I would avoid using discrete logic blocks.
You also need to look at Real Time Clocks (RTCs). these cute little chips have a 32Khz oscillator connected to them and increment seconds, days, months, years, day of week etc and take a whole ton of grief away from clock designing.
As for the 7 segment display, take a look at the MAX7219. this drives 7 segment displays.
But you really need to start with a micro at the heart of the design and you can learn PICs in a matter of days - and there is a whole ton of software on the net to get your started!
I cant use a microcontroller.
Ive worked on it a bit more and i think i got the "seconds" portion down but i need to create a 60hz signal to connect to pin 14 on the first 7490 correct?
How can i do this? I read using a 555 timer is inaccurate and that i should produce it using a crystal? How do i go about doing this?
I attached the part for the seconds. Is that correct?
You need an accurate 1 Hz signal. A 555 is not accurate enough. There are 3 obvious frequency references that are accurate enough.
50 or 60 Hz mains. The mains signal can be transformed to a safe voltage and then divided by 50 or 60 to give 1 Hz
32768 Hz watch crystal. You need a simple oscillator circuit followed by a divide of 32768. There are lots of ICs that will divide by that.
A higher frequency crystal. Again, a simple crystal oscillator, followed by a suitable divide. That may take more ICs.
Your circuit to divide by 60 looks OK. Do you want the displays connected to the 7447s in your diagram to show minutes or seconds?
Can you give me a diagram please? Also im simulating this in multi sims. Does it have crystals in its database?
I also have to make this run off a 9v battery. I have to reduce it down using a 7805 though correct?
I have the displays connected i just couldn't fit it in the screen shot. The 7 segment displays are connected to the corresponding pins on the 7447's. I have to run a 220ohm resistor in between each though correct?
Okay...
To make a simple digital clock, I would firstly choose a nice good stable clock source. this is just a square wave that has a frequency of 60Hz. You could use a 555 timer but it would need to be fine tuned with a potentiometer. I would suggest using a pierce oscillator which allows you to use standard crystals to genetate a square wave clock signal (Pierce oscillator - Wikipedia, the free encyclopedia).
Now that you have this 60Hz signal just use a bunch of counters
i.e.
Clock Signal -> Seconds Counter -> Min Counter -> Hour Counter.
The seconds/min/hour counter will all comprise of 2 counters each.
You could then use some gate logic to link seconds to min and mins to hours. i.e when the first digit of the seconds is a 6 then reset and clock min
Hope im making sense.
