Old 15th February 2009, 10:58 AM   #1
Default Power-Up Latching Relay
The purpose of the circuit is to create a switch which cannot change position after power is applied to the circuit.
The position of the switch must be set before power is applied. After power-up, the position of the switch is locked.
The schematic shows a SPDT "RUN/OFF" switch on the left, and the coil of a DPDT relay on the right.
If the switch is set to RUN, the relay will actuate roughly one-half second after power-up. If the switch is set to OFF, the relay will not actuate.
In either case, the switch will have no further effect after the power-up initializing period.
This circuit has been built and tested. It currently works reliably in a computer with a second hard drive. It prevents power from being applied to or removed from the hard drive while the computer is on.
The switch contacts of the relay control both +5V and +12V to the power input of the hard drive. There is an LED indicator on each of these rails to confirm power.
The heart of the circuit is a set-reset flip-flop constructed from gates B and C of a quad nand gate.
The timing diagram shows waveforms at points labeled in the schematic for the two conditions RUN and OFF.
The assembly diagram shows the top side with components in the top half of the picture and the bottom side with wiring in the bottom half of the picture.
This design is completely original by yours truly and it is free use (at your own risk of course!)
Comments and criticism welcome.
Power-Up Latching Relay-hdd-latch-schematic.gif   Power-Up Latching Relay-timing-diagram-gif.gif   Power-Up Latching Relay-layout.gif
JBrock is offline
Old 15th February 2009, 04:10 PM   #2
Jbrock, Thank you.
I may want to use this someway to bring a relay in to power an outlet driven of a control panel for a light circuit.
I want this outlet to have power only when people are at the University. When my operators close up the control room the will shut down the control panel thus powering down the relay.
kv
Truthiness Monkeys : Obedience, Ignorance, Fear.
killivolt is offline
Old 16th February 2009, 05:39 PM   #3
This is great. I just want to add to further robust the design. Additional protection for the BJT is needed. Either a free-wheel diode // in the relay coil or a TVS // in the CE of the BJT.
Chaerl is offline
Old 17th February 2009, 10:09 AM   #4
Thank you!
Could someone please tell me how do you implement the logic gates using Mosfets or BJTs?
alphadog is offline
Old 17th February 2009, 04:14 PM   #5
Is this what you are looking for?
HTML Code:
http://hyperphysics.phy-astr.gsu.edu/HBASE/electronic/trangate.html
Chaerl is offline
latching, powerup, relay
Latching relay driver baba_sanfur Electronic Projects Design/Ideas/Reviews 2 12th February 2009 05:43 PM
high power latching relay carmusic Datasheet/Parts Requests 27 22nd December 2008 11:12 PM
bi-stable latching relay? wsemajb General Electronics Chat 10 4th June 2008 12:32 AM
What is a latching relay vers a non latching relay MrDEB Electronic Projects Design/Ideas/Reviews 7 22nd November 2007 02:44 PM
Wiring a latching relay behrendfry Electronic Projects Design/Ideas/Reviews 8 4th January 2006 06:00 PM
