Here's the plans for a power supply I'm intending to build. By my claculations it should provide me with +-15.7V@1.5A. The mains transformer I'm using is a 15V-0-15V torroid rated to 2.67A which is slightly over-rated which is perfect as the regulators might not current limit untill 2.2A. Anyway, I just thought I'd ask you lot if you can think of any improvements before I etch the PCB and build this.
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. Last edited by Hero999; 27th September 2006 at 04:56 PM. | |
Not that anybody cares but I've nearly built this project. The PCB is finished and the componants are all soldered in place. The circuit works quite well the -V supply is alway within <10mV of the +V supply which is as close as fu*k is to swearing. My work's calibrated meter would show 0.01V difference on the 0-20V reading and 0.001V on the 0-2000mV setting, this is probably due to the tollerence in the meter rather than the circuit. I did consider using a better op-amp than the uA741, but then I thought I have no need to as it's only acting as a DC amplifier and the regulator IC will handle all the load transients, besides I've got loads of them in my junkbox. I've drilled all the holes in the box and mounted the terminal posts. All I need to do is drill the holes for the power switch, LED, voltage adjustment pot, and power connector. When I've completed it I'll post some pictures providing I can find my digital camera.
| | #3 | |
You asked if there were any improvements to be made, I could not think of any, and presumably no one else could either. So, take heart, you have built it, it worked in the way you expected first time, that sounds like a success to me. Award yourself a few brownie points JimB
__________________ Experience is directly proportional to the value of the equipment ruined. | ||
Point taken, it's had 35 veiws now. I've made the hole for the power connector and drilled the hole for the potentiometer. Progress has been slow because I'm doing it at work. Hopefully I'll have it finished by the end of the week.
I've finnished this thing last week but I've only got round to giving it a full test and I'm still quite satisfied even though it isn't quie as good as I first thought. At the maximum output voltage the -V input is about 25mV lower than it should be, while at the lowest setting it's spot-on. This is because the inverting amplifier has a slightly higher gain than one which I is due to the componant tollerances. Even though I haven't bothered with a proper heat sink (I've mounted each regulator on a piece of copper and fixed it to the metal case which is being used as the heat sink), it performs quite well and the box doesn't get too hot even when short circuited. I hope to get my digital camera back soon (I'd lent it to my brother), as soon as do I'll post some pictures.
| | #6 |
It shouldn't get hot short circuited as the chips shut down all together in that condition. Running at near the max (1A or so) it will do, but shouldn't overheat if your heatsinks are suitably sized. I', interested in the pics . I like the design, where they track each other. Mine has 2 controls and thats awkward, mabye I should change it to this design.
__________________ Angry!? I'm absolutely electrolytic! Music web page: http://www.music-playground.net/artist/drem/ | |
| | #7 | ||||
Anyway, you've convinced me I need to do some more performance testing at the highest and lowest voltage settings. I have one more trick with an op-amp and a uA714 that can make the LM317 go all the way down to 0V. I'll post if you like, but I don't really need it.
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | |||||
| | #8 |
Oh well I'll post it anyway.
| | #9 |
Have you done the ultimate test yet? A direct short circuit between +ve and -Ve at maximum output voltage, done several times with a few seconds in between. If the power supply survives, then it has passed the test.
__________________ L.Chung | |
| | #10 |
Yes, that was my first test and of course it survived, the LM317 & LM337 just shut down. When I've done the other tests I'll post the results.
| | #11 |
Nice job, Hero! Have you looked at the outputs with a scope? Have you done transient load tests? I would be wary of marginal loop stability (poor phase margin) in the negative regulation circuitry. If it is a problem, a cap (10nF?) from the 741 outout to its inverting input might help. If it's not a problem - | |
| | #12 |
That's all in the pipeline. I didn't think the loop stability would be a problem because the LM337's gain is in effect unity, remember it's only subtracting Vref from the output of the 741 - it's acting like an emmiter follower.
| | #13 | |
| | #14 |
Another thought: if you use the 120 ohm resistor the current is quite high: about 10 mA... an LF411 can be a good replacement for the ua741?
| | #15 | |||
The only reason I'm using a LM337 for the negitive supply is because it will shutdown if overloaded, it could just as easilly be a normal transistor.
| variable power supply | tom hewitt | General Electronics Chat | 2 | 4th January 2008 08:51 PM |
| variable voltage power supply | mahmoud shendy | General Electronics Chat | 8 | 28th December 2007 06:23 PM |
| Bipolar power supply with digital control | GizmoWizard | Electronic Projects Design/Ideas/Reviews | 11 | 15th March 2006 02:53 AM |
| Variable DC Power Supply | Night Thrasher | Electronic Projects Design/Ideas/Reviews | 8 | 10th January 2006 01:11 PM |
| variable power supply | jimmythefizz | Electronic Projects Design/Ideas/Reviews | 9 | 4th October 2004 06:37 PM |
