Old 23rd March 2005, 08:59 PM   #1
Default Project: Transformer Checker
hi
simple way to test your transformer :lol:
Project: Transformer Checker-xform_test.gif
hsab is offline
Old 26th March 2005, 11:20 AM   #2
Hey...
Can anyone explain this ?
The coil is supposed to provide 0 resistance to DC(The cell). So wont it be just a small change in intensity if the coil is short or not ?
Bharath Bhushan Lohray.
M.Sc. Electronics.
lord loh. is offline
Old 26th March 2005, 11:54 AM   #3
Originally Posted by lord loh.
Hey...
The neon flashes when you release the button, not when you press it, it's due to the back emf caused by the collapsing magnetic field in the transformer. It's the same effect used in car igntion coils.
If the transformer has a shorted turn it seriously dampens the 'ringing' of the transformer, and the back emf won't be high enough to light the neon.
It works with any reasonably sized coil (not just transformers), even 1mH RF chokes will do it - just wire a neon directly across a choke and briefly apply a battery across it - the neon will flash as you disconnect.
Old 26th March 2005, 01:33 PM   #4
if you hold the contacts of an high inductance coil (electromagnet and stuf like that)Wile conecting and disconeting a batery you will get a shock.the higher the indictance the biger the shock.
this is a fenonemom that is cased by the magnetic field.Wen you conect the batery the coil makes an electromagnetic field around it wen you disconect the batery the field breaks down resulting in an high voltage spike on the contacts.
in this tester the high voltage spike is used to flash and neon bulb
This was used and is stil now to make high voltages (an car initon coil is a good exsample)
my shocker in the projets page uses this fenomenon to to make voltages up to 3000V from an 6V batery.
I once toced the electromagnets of an operating bell (run from an batery)I got an shock(it wasent wery plesent)
Il give you shocking experience.
Someone Electro is offline
Old 18th April 2005, 07:30 PM   #5
thats true. i see that circuit before in a magazine. :lol:
What If Cold Fusion Is Real?
positive logic is offline
Old 29th May 2005, 05:09 PM   #6
Default Re: transformer checker
Originally Posted by hsab
hi
if the transformer works in reverse mode i beleave it may work in forward mode, a simple circuit to test the reverse mode transformer is a simple scr circuit useing an scr and a resister or 2 and a 12 volts battery and a 12 volts auto indicator flasher unit from a car will do the job
steven from australia
steven is offline
Old 3rd June 2005, 06:37 AM   #7
hmm
i just use my continuity tester to test transformers
moody07747 is offline
Old 3rd June 2005, 08:16 AM   #8
Default transformer testor
[quote="moody07747"] it can be done with a multimeter set to low ohms to especially for finding the correct outputs if the transformer has 4 or more wires
steven is offline
Old 23rd February 2006, 09:14 PM   #9
Default transformer tester
what it will do if there is an open in the transformer primary and/or secondary wiring and my second quwestion is if the transformer is a multi voltage primary and secondary type, should we connect to each of the voltage input/output wires separately
changiz is offline
Old 24th February 2006, 07:51 AM   #10
No flash if the transformer has an broken coil since no curent will run trough.
If it has taps use the uper and the most botom tap since this way you get more inductance
Old 11th March 2006, 08:45 AM   #11
can any one xplain this circuit
chaisi is offline
Old 11th March 2006, 09:37 AM   #12
Try reading the previous posts!.
Old 7th April 2006, 06:39 PM   #13
Be careful, if you apply a pulse like this to the primary of some mains transformers and you can get a very high voltage at the secondary (in the order of 10kV), this can destroy the insulation.
if I know the answer.
Hero999 is offline
Old 13th April 2006, 10:35 AM   #14
my multimeter set to ohms does the job........
sheldonstv is offline
Old 13th April 2006, 10:42 AM   #15
But only tests if the windings are O/C.
checker, project, transformer
