Hi. I am trying to cascade three 4017 counters inorder to light 27 leds and have them constantly run. I have found WEB sites on one 4017 but nothing on how to cascade them. I am using a 555 timer for the clock pulse. Thanks; William | |
Connect Carry Out from the first to CE of the second and tie C high. Repeat for the second and third counters. Look at the data sheet for the 4017. EDIT: On re-reading your post, I don't think 3 X 4017 will do what you want. I assume you want to illuminate only one LED at a time. Is this true? If so, then you need a modulo 27 counter with suitable decoding.
__________________ Len Last edited by ljcox; 8th March 2007 at 07:50 AM. | |
| | #3 | |
__________________ Creationists have a world of evidence | ||
Page 6 of this datasheet from On Semiconductor shows how to do what you want ... Also, here's the parent MC14017B page ... <link> JB *edit* You'll need (4) 4017's to run 27 leds ... 3 will only run 25 ...
__________________ Nothing is impossible for the man who doesn't have to do it himself - Weiler's Law Last edited by jbeng; 8th March 2007 at 11:15 PM. | |
Hi jbeng. I made a mistake on the count of LEDs I only need 25. So using four chips is no problem for me but I'll need some help. also answering Allvols question I am trying to make a light sequencer or light chaser. Thanks William Last edited by purcer; 9th March 2007 at 07:14 AM. | |
| | #6 | |
I assumed he wanted 27 LEDs that turn on in sequence so that there is always one LED lit, he would need a Mod 27, ie. 0 ~ 26. But if he wants the LEDs to be all off in one state, then he needs a Mod 28.
__________________ Len | ||
| | #7 | |
| | #8 |
Hi Len I need one led on all of the time. Wiliam | |
| | #9 |
I assume you want it to be in a continuous sequence, ie. 0, 1, 2, 3, ... 24, 0, etc. Or do you want it to be in a random sequence? This is more complex.
| | #10 |
Hi Len Yes 1 2 3 4 up to 25 and I need one light on at all times. William | |
| | #11 |
I'll post a circuit tomorrow.
| | #12 |
Hi Purcer, Here's a circuit that will do the trick. From the first 4017 you use outputs "0" to "8", from the second 4017 you use outputs "1" to "8" and from the third 4017 you use ouputs "1" to "9" to drive the leds. That's a total of 26 leds. If you only need 25 outputs, use outputs "1" to "8" from the last 4017 to drive the leds and move the 1 nF capacitor which is connected to output "0" to output "9". Connect each led with a suitable resistor in series from each output to ground. on1aag. | |
| | #13 |
Here is my suggestion:- U1 & U2 are configured as Modulo 5 counters. The LEDs are arranged in a 5 x 5 matrix. LED 0 glows when U1 = 0 and U2 = 0. When either U1 or U2 = 5, the counter is reset rapidly. U2 is advanced when U1/0 goes high. I have not included a "power on" reset. Therefore, since the counters will start in random states when the power is turned on, it may take a few clock pulses before the normal sequence starts. If you can't buy a 74HC4022 or 74HC4017, let me know and I'll show you how to do it with a 4017, but it will require an extra IC since the 4017 may not have enough current source capability to drive the LEDs. Choose resistors R0 ~ R4 for the correct LED brightness. For red LEDs, about 470 Ohm should be adequate. Choose R & C according to the oscillator frequency that you want. I would make R = 1M and choose C for the frequency you want. The formula is f = 0.56/(RC) approx. (very approx)
| | #14 |
With a 9V battery, the output current from an ordinary 4017 is about 12ma. A current-limiting resistor is not needed for the LEDs. When the battery drops to 6V then the LEDs will appear dimmer. The absolute max continuous current allowed from the output of a 74HCxx IC is 25mA which looks only slightly brighter than 12mA, a regulated 5V supply is needed and a current-limiting resistor is needed.
| | #15 |
Here is a variant on that posted by on1aag. Note Audio's point about the 4017 and operating the circuit from 9 Volt. So you could use 4017s with this arrangement.
| 4017, cascade, counters |
| 555 & 4017 | mozikluv | Electronic Projects Design/Ideas/Reviews | 14 | 16th June 2008 06:08 AM |
| HCF 4017 Equal Ic's with more Outputs | Gayan Soyza | General Electronics Chat | 2 | 20th November 2006 02:26 PM |
| 16-step sequencer from two 4017 decade counters? | october71 | Electronic Projects Design/Ideas/Reviews | 12 | 29th January 2004 10:11 AM |
| Music Effects with 4017 and 555 | afs87 | Electronic Projects Design/Ideas/Reviews | 5 | 20th June 2003 06:21 PM |
| Working with the 4017 | fantasymick | General Electronics Chat | 3 | 18th May 2003 05:41 AM |
