Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
I have that panel, its a 32 pin connector. No mfg marking, the mating cable connector is stamped JAE on the grounding shield. However, copious searches on JAE, does not yield a 30 pin connector of that flavor, just 30pin.
On the PCB of the LCD, you can see where they label pin 1 and then pin 32 at the other end.
I have had no luck finding the datasheet on that panel...
[EDIT] The connector on the cable side is 30 pin - the board connector is 30pin, but two additional "pins" that are shield grounds.
The connector is made by JAE , and initially looks to be a FI-X series connector. I have to verify some of the spec measurements to be sure.
No problem, glad to help. Its LVDS. The majority of panels that I have hacked on are LVDS. In fact some of the spec sheets even mention which TI chip to use on the transmit side etc.
Thats for the additional information - You won't be able to hook any panel up straight forward to a PC via a DVI connection. The reason for this in basic terms is that the LVDS signal is low power, and is translated to DVI via a chip so that it can run the 4-6ft without signal degradation to the monitor. You also would have to drive the CCFL tube to backlight the panel to see the picture. There are lots of links on google etc on what you can do to hook up an LCD to a PC. But its not straight forward.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
