- Blog entry posted in 'Uncategorised', April 23, 2010.
The following code receives a character over an RS-232 connection. It's been tested and verified using Xilinx FPGA.
Use the following settings in your terminal program:
Baud : 9600
Data Bits : 8
Parity : None
Stop Bits : 1
Flow Control : None
module loopback
(clock,
reset,
RS232_DCE_RXD,
RS232_DCE_TXD,
receive_data);
input clock;
input reset;
input RS232_DCE_RXD;
output RS232_DCE_TXD;
output receive_data;
parameter rcv_bit_per = 5208; //102.4uS
parameter half_rcv_bit_per = 2604; //51.2uS
//--State Definitions--
parameter ready = 2'b00;
parameter start_bit = 2'b01;
parameter data_bits = 2'b10;
parameter stop_bit = 2'b11;
reg counter, n_counter; //9765.625Hz
reg data_bit_count, n_data_bit_count;
reg rcv_sr, n_rcv_sr;
reg state, n_state;
assign RS232_DCE_TXD = RS232_DCE_RXD;
assign receive_data = rcv_sr;
always @(state, RS232_DCE_RXD, counter, data_bit_count) begin
n_rcv_sr <= rcv_sr;
n_counter <= counter;
n_state <= state;
n_data_bit_count <= data_bit_count;
case (state)
ready: begin
if(RS232_DCE_RXD == 0) begin
n_state <= start_bit;
n_counter <= counter + 1;
end
else begin
n_state <= ready;
n_counter <= 0;
n_data_bit_count <= 0;
end
end
start_bit: begin
if(counter == half_rcv_bit_per) begin
n_state <= data_bits;
n_data_bit_count <= data_bit_count + 1;
n_counter <= 0;
end
else begin
end
end
data_bits: begin
if(counter == rcv_bit_per) begin
//n_rcv_sr <= {rcv_sr, RS232_DCE_RXD};
n_rcv_sr <= {RS232_DCE_RXD,rcv_sr};
n_counter <= 0;
if(data_bit_count == 8)
n_state <= stop_bit;
end
else
end
stop_bit: begin
if(counter == rcv_bit_per) //should be 1/2 stop_bit period
n_state <= ready;
end
endcase
end //always
//clock proc
always @(posedge clock or posedge reset) begin
if(reset == 1) begin
state <= ready;
rcv_sr <= 0;
counter <= 0;
end
else begin
state <= n_state;
rcv_sr <= n_rcv_sr;
counter <= n_counter;
data_bit_count <= n_data_bit_count;
end
end
endmodule
BrownOut, April 30, 2010
Thanks to killivolt for catching my big, fat typo. Still trying to figure out how to edit the entry. Got it! Yea! Thanks to Hans for asking how on the forums, and to Eric for providing the solution.
vanhayder, July 10, 2011
hi....i need your help.. i want to write a verilog code that connect pc to rs232.....and i am lost totally.....the whole thing is to connect pc to pc using rs232 =>spi.....spi=>rs232................i just need the first part code plz........any suggestions thanks a milon
