Place EEPROM at byte boundaries in Pic18 series.
Pommie
Most Helpful Member
If I take a simple program with bytes placed at word boundaries all works well. No errors,
If I now change it to byte boundaries I get,
Note, the only thing changed is the address where the second byte goes.
The error is on the fourth line up starting ::: error:
It appears that XC8 has decided the EEPROM needs to be on word boundaries like the program memory.
Does anyone know why this is or a work around?
Thanks,
I just use the inbuilt function
__EPROM_DATA ( x,x,x,x,x); // x is byte size.
The method you are using is aligned. BUT in powers of 2.. So Int Long etc..
In MPLABX in the help file under eedata / Data memory allocatiion.
OR!
const int mydata __at(0xF00000) = 0x55AA;
