Bosch Alternator Regulator LIN
majshumlan
Hi!
Im building a car and have this Volvo Alternator 180A layin around that I think it would suite my needs fine.
Though it have this LIN -ECU controlled regulator.
Im not sure if this could be solved some how.
Change the regulator to none LIN?
Let it run in fail safe mode with or without a external regulator?
Other ways?
Info of the Alternator(It will run with a Chevy 383 V8)
Alternator: Volvo 30659131 from a 2015 V60 D4
Regulator: Bosch F00M346166
Cheers!
Peter: This is a carbuild. A Lotus chassie with a Chevy 383 V8.
Im building the electronic system from scratch.
Diver300: That would be the option of running it in failsafe mode without the LIN bus.
Anyone know if the regulator gets its Logic power supplied from the LIN bus wire?
The alternator voltage regulator powers the field winding to adjust the voltage. It needs a couple of amps to do that. The LIN signal itself can't provide that, so the alternator regulator must get power from the B+ terminal.
Hi there, I am in a similar situation:
My car originally had a 180A Bosch Alternator but I decided to upgrade to 220A Valeo from a newer car. However the 220A alternator has a regulator with just 1 pin, and ever since the replacement the car would idle at a higher rpm (300rpm more).
I suppose my old alternator was the DFM type and new one has the LIN-BUS type? I saw a post about conversion but the wiring seemed like a pain, would it be okay if I just take out the alternator and change the regulator? Any advantage of LIN-BUS regulator over the DFM ones? Thank you!
Old:
New:
I would not know whether the alternator regulator could be changed. There could be significant differences that would make using one regulator on a different alternator very difficult.
With a different alternator the communication to the car simply won't work. The alternator will most likely have a default behaviour if it can't communicate, and that is probably to run at 14.4 V. The car's default behaviour appears to be to idle at the highest speed that it would if the alternator ever asked for more speed.
Without seeing waveforms etc. it's very difficult to know what the car is expecting.
One possible solution that might work would be to connect the regulator from the old alternator so that it can communicate with the car, so that the idle speed is normal, but leave the new alternator actually generating the electricity.
